  • Replies 162
eManage and other piggy backs are limited by design. You can only 'fool' the stock ECU so much by the time you throw n bigger injectors, turbo etc. Good for light to mild upgrades though.
Its not like an SAFC though. You don't just fool one input, being AFM in the SAFC.
The emanage actually has outputs directly to the injectors and ignition from my understanding. This gives you full control, not an indirect control.
Guys,
thanks for your comments and info! keep them coming!!
Paul, if I could find a 2nd hand PFC for a good price, yes I'd probably go for it - been checking sidewise/yahoo on a regular basis but for a R34, there isn't much.
ALSO, the old supply/demand – value for money, the price of a 2nd hand PFC has gone up. About the same as a NEW e-manage Ultimate (with warranty, newer technology, laptop connection, etc)
As per my original post, I’m not going for the top end (Haltech, Motec, etc). The budget will be $2000 max (that’s installed & tuned).
As for the long term plans for the car – I can’t see me doing any major mods. Knowing the ecu has some flexibility/room for growth is important – looks like the e-manage has that.
Yes, I can see the ‘Tuner’ playing a major role in all of this…I know some ECUs like HSK don’t have any support up her in QLD. Not sure about Wolf and a few of the others.
Dan, I’m keen to have a chat about your ROM option. Brisbane tuners that will support this, etc. Maybe when I pickup that TCS device (*free plug*), we can have a chat.
Michael, thanks for the info - I have seen this before, but as a noob, I'm still figuring out all the details 
I think I’m looking more for the Pros & Cons or some type of side by side comparisons between the leading ECUs
Pros/Conc like – Piggyback vs replacing the stock ECU.
People seem to think the piggyback idea is bad, but is this based on the NEW functionality found in the e-manage Ultimate?
Thanks again!
Still a very limited product for the more basic end of town.I tune a few these days and its easy to find its limit.Haltech Inteceptor is much like the Emanage but i find it a better system but its pushing plug and play money.Closed loop also becomes a problem with big mods and these 2 benders,Sometimes even having to unplug the Oxy sensor and thats really not on for our road cars.
There are a few R34's that have had an R32 ecu wired in insted of the R34 ecu. this is due to the tunability of the factory R32 ecu.
you can pick one up for $100 have it socketed for $30 and wired into your car for around $200 and you can even have nissan consult software checking everything and outputting it to a laptop for you.
then any have to do is pay someone to tune it.
There is one downside... VCT can not be controlled by an R32 ecu so you would need an aftermarket controller.
includng a controller you could have it in, tuned and done for around $1000
good value IMO...
If I didn't already get my hands on a PFC I would of gone the emanage ultimate - although prolly biased as I have the Profec E-01 boost controller which acts the same as the PFC hand controller when connected to the emanage.
good value IMO...
Easy fix,Use a Z32 ECU remapped,Problem solved.
i stll reckon the PFC will win hands down
Paul, I'm sure you are right... but WHY?
what are the BIG differences that has the PFC 'hands down' over the eManager Ultimate?
NIB, thanks for your comments... I think I am sitting at the low to mid end of town... I can't see my mods ever going too out of control.
Have you (or anyone) found that the eManage Ultimate is better to work with than the older 'BLUE'?
From what I could see, there seems to be a lot of new features, but maybe still very basic??
r33 powerfc
almost 1800$ !!!
sheesh!
i hope nothing happens to the 3 i have getting posted , all procured under 1200$
wow, that's huge...
There's way more r33 gtst units in circulation.
My chances of getting a 34 gtt version isn't looking good :devil:
hmmmmmmm its pretty bleak...... but i've talked to one tuner that says shouldnt be much a problem tuning the emanage ultimate and still think it'd be capable of handling the mods and power that people want, im just after round 250 rwk...
all of us have other shit to deal with bills, naggin gf, beer... so money has to be well spent...
r33 powerfc
almost 1800$ !!!
sheesh!
Sh!te... perhaps I should auction mine off and get the emanage ultimate... :(
the wnner of that was a bit over enthusiastic
i got 2x 33 and 1x34 all under 1200$ in the last week
If you find an ER34 model for a good price, please let me know :D
were your 3 units new or 2nd hand?
^^^^^what he said
actually in the interests of the community i think ill spend some time on it
it cant be too hard surely?
Good luck paul - keep us posted!
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
