www.uras.com.au
Email Athid: [email protected] PM: 180athid He'll sort u out!
If u need a good painter, u cant go past Vu @ DT panels; email: [email protected] PM: evilsub
those things are ugly and URAS only do 4 doors which i dont have
Is this pretty much asking the same thing?
http://www.skylinesaustralia.com/forums/in...howtopic=149367
oh no nismoid ull have to wait and see what that is :(
Edited by anDru
I've decided to go with GTR guards, front and rear.. Rear will need a cutting,welding job etc.. but overall, pumped out GTR guards look the best! Can get those wheels i wanted with a +45 offset.
Just need a wreaking GTR with a straight rear panel now!
custom stuff will aslo cost alot of the $$$$
lol give me a couple of weeks mate ill have my new car pics up and exactly how much its cost me to get it up to that stage......then ull see wat alot costs lol
my cars in my shop Daniel its almost ready just a few lil touch ups n get my speedo working somehow?? n yer
iv had custom work b4 it cost lost off money better off buying premade kits. if it dont cost u much then its shit lol unless u got a mate
I've just converted my front R33 S1 to GTR. Trust me it costs more and requires a lot more effort than you realise. This is what I needed that was different:
- GTR Bonnet (taller, longer).
- GTR Bonnet Hinges.
- GTR Bonnet Latch.
- GTR Headlights (Look the same as S1 R33, except have additional spacers).
- GTR Front Guards.
- GTR Front Guard Inner Liners.
- GTR Front Guard Raisers (Piece of metal that sits between guards and skirts - $300 pair from Nissan, goodluck getting from wrecker).
- GTR Indicators.
- GTR Front Bar (Even FGlass is expensive as not many around for GTR)
Now do the maths.
It cost me $2500 just for parts, and that was cheating, having modified the hinges/latch and using fibreglass front bar and bonnet. Plus another $2200 labour for fitting and painting, and it becomes a very expensive exercise. I'll post photos when I get a change though, looks insane! Better than your average R33. Now time for the rear =(
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
