www.uras.com.au
Email Athid: [email protected] PM: 180athid He'll sort u out!
If u need a good painter, u cant go past Vu @ DT panels; email: [email protected] PM: evilsub
those things are ugly and URAS only do 4 doors which i dont have
Is this pretty much asking the same thing?
http://www.skylinesaustralia.com/forums/in...howtopic=149367
oh no nismoid ull have to wait and see what that is :(
Edited by anDru
I've decided to go with GTR guards, front and rear.. Rear will need a cutting,welding job etc.. but overall, pumped out GTR guards look the best! Can get those wheels i wanted with a +45 offset.
Just need a wreaking GTR with a straight rear panel now!
custom stuff will aslo cost alot of the $$$$
lol give me a couple of weeks mate ill have my new car pics up and exactly how much its cost me to get it up to that stage......then ull see wat alot costs lol
my cars in my shop Daniel its almost ready just a few lil touch ups n get my speedo working somehow?? n yer
iv had custom work b4 it cost lost off money better off buying premade kits. if it dont cost u much then its shit lol unless u got a mate
I've just converted my front R33 S1 to GTR. Trust me it costs more and requires a lot more effort than you realise. This is what I needed that was different:
- GTR Bonnet (taller, longer).
- GTR Bonnet Hinges.
- GTR Bonnet Latch.
- GTR Headlights (Look the same as S1 R33, except have additional spacers).
- GTR Front Guards.
- GTR Front Guard Inner Liners.
- GTR Front Guard Raisers (Piece of metal that sits between guards and skirts - $300 pair from Nissan, goodluck getting from wrecker).
- GTR Indicators.
- GTR Front Bar (Even FGlass is expensive as not many around for GTR)
Now do the maths.
It cost me $2500 just for parts, and that was cheating, having modified the hinges/latch and using fibreglass front bar and bonnet. Plus another $2200 labour for fitting and painting, and it becomes a very expensive exercise. I'll post photos when I get a change though, looks insane! Better than your average R33. Now time for the rear =(
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
