Guest INASNT
Originally posted by DJ_L3ThAL
yer i got my powerfc done by ice, and nigel spent ages fine tuing it on ther dyno but still on cold nights and under differnt loads etc i got some pinging, i just noted when this happened and went back as i found new areas that needed fine tuning and we ironed them out within a week, think i onloy went back twice which was awesome considering now my car is 100% ;)
ho did u know it was pinging?? was the knock reading over 60% on the h/c ?
  • Replies 50
this powerfc sounds interesting....
i have not owned or study it at all....although i did test drive an r33 which had one installed... it went nice and hard....
can you tell me how much they cost and where i can find technical info on them?
after using LINK, Wolf 3d, Haltech, seeing what motec can do and studying autronic, i would love to compare.
Originally posted by king_kw13
what are big power mods Al? Is big power mods defined as
- Larger Injectors?
- Aftermarket Cam Shafts?
- Aftermarket Turbo?
- FMIC?
- Big NISMO Sticker?
First three. Forth can be delt with by the apexi, and the fifth by the wanky ricers :P.
The best programmable ecu, is the one your trusted mechanic can tune. No use having a Wolf if he has only delt with a Pfc and isn't able to extract and use all features :uh-huh:.
But if you plan to change the first three items listed above, do the ecu first, as this alone will give you a noticable differance.
my 2c
Good luck with your decision
Guest INASNT
Originally posted by Jay95R33
rs73 - yepp, that's my understanding.
I've heard 'stories' of people pluging in a new PFC and gaining 15rwkw just from the base map it comes with..
Not sure how true this is, but sounds tempting.
J
u may get a slight power increase but the car will be pining off it tits as the fuel maps r based on jap 104 RON fuel
i wish it was that simple that the best ecu is the one your mechanic can tune the best.
Personally i would, and have always had my cars tuned by the workshop the particular ECU company recommended to tune, supply and fit.
Originally posted by rs73
Al,
why you wouldn't wanna change factory IC with FMIC, considering with afm injectors, cam, & turbo?
what would be the factory IC efficiency is, don't think it will be effective for boost above 12 psi.
The original question was: what do i consider big mods to justify a ecu replacement. If you only plan to go as far as a fmic i am suggesting to use a apexi safc to trim the fuel curve. Of course you need to replace that shitty factory ic. If you are planning a turbo upgrade, etc. than a replacement ecu is a priority.
my 2c
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
