Hi :D
am new member on this forum - just few days ago I bought SKY r33 from Japan its 93 years model with hicas and lsd, i need some information about this car anyway its firs sky in Tbilisi so this forum is my only hope:) firs of all i need to know where ECU is displaced and what is turbo PSi boost??? i know its 7psi is that correct?? and what modifications shoud i do for? I have seen the intercooler on stock its so small:) will i have any extra hp or more PSI in turbo after installing intercooler kit??
please be kind and give some advice
and thanks for helping
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/
Welcome to Skylines Oz.
The ECU is found on the pasanger side front kick panel. This is the panel directly below the glove box. You will see a 10mm plastic nut, undo this and pull the cover off, it takes a bit of fore to unclip it, be gentel through. (if you sit in the pasanger sit, and rotate the left foot towards the outside of the car, you will hit the panel behind which the ECU can be found.)
The stock ecu runs 5psi below 4500rpm and 7psi above that, there is a hack to make the car run 7psi all the time. Look under the DIY section.
In regards to modifications, get a full exhaust, a good boost controller and posibly a new fuel pump, as skyline ones a notourious for failing, posibly a new computer or a pigyback one, and 200rwKw or 270hp at the rear wheels is easy to get.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2863268
Wouldnt Georgia be better off with 4wds? :(
Tbilisi is a city with over million people so im sure there is lots of sealed roads
i would get rid of the hicas save 20kg in weight and makes for a better handling car
it must be cool 2 have the first line in Tbilisi
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2869893
About roads we have no problem:) I can tell you roads in Tbilisi and central magistral roads are better conditon in Caucasus:) and we have RUSTAVI track its 4.4 km long its not LAGUNA SECA but road cover is in good condition so people dont have any problem with adrenalin:) 2 days ago i Install boost gauge its shows more than 7 PSI its mneans turbo is ok, actualy this is my first Japan car because mostly Georgians are Bavarian fans:)
this is my sky i run 402 meter 13 .55 sec i think its ok for stock car without any modifications and again i have miss when changing gear from second to third:) i think i need time because i have run onle just 500 km yet, and there is video of my car and BMW 540 actualy 4.4 engine with 286 hp with tiptronic gear box and we push acceleration after 50 km in hour:) BMW 540 VS R33 GTST
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2869920
That doesn't sound like a stock R33 gtst. If it was stock, it would be in the 14's. The fact that you run over 7psi shows that it isn't stock aswellr.
Edited by jantolis
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2870006
Ah ok. Nice car you got there mate!
thanks mate:) are you Russian??:ninja:
car is completely stock without modification i check it ! opens turbo above 3000 on 4500-5000 with missfire:) and than shows 7-8 psi before that till 5... car is with original muffler and exaust system
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2871196
Mods? Exhaust - ECU - Intercooler - Boost controller? then worry about everything else! :laugh:
do you have links of this items?? where i can find them??? what you mean ECU it there any GTST ECU modifications???
and do anybody know how much i can boost turbo witout angine modification, actualy its now araund 8 PSI
thanks again:)
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2879560
thanks again:)
Hi mate,
the highes you should go is 12psi maximum, 10-11 is safer. Over 12psi and ur exhaust wheel on the turbo will blow off. you shoudl upgrade your intercoole rif your running more boost. Also get a full exhaust system.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2880582
need help i find this intercooler kit on ebay http://images.channeladvisor.com/Sell/SSPr...FMICRSB-JDM.jpg
is it ok??? price is so cheap maybe someone sugest write address where i can buy it
thanks
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2891615
Hi mate,
Please Help!
I bought boost controller but I dont know what is recomended PSI what i can boost on GTS25T? car is absolutely stock....
Please Help!Please Help!Please Help!;)
What tmc_2 said. Go 10psi. Although if you haven't put a full exhaust system on yet, don't boost it at all. The stock system is very restrictive and you won't reap the best benefits. Intake & Exhaust & intercooler first (although its probably colder there anyway), then boost.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2907106
Heya guricha welcome to the wonderful world of Skylines! This place is full of really helpful information and everyone on here is happy to help and wont look at you like your a dumbass for asking any sorts of questions...
Just think of your Skyline as your new girlfriend LoL ;)
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2907148
Just think of your Skyline as your new girlfriend LoL :)
Hi thanks for help you are only hope for Georgian Skyline:) please sugest intercooler kit i found them on ebay and cost araund 160$, i have no experience in that and are this intercoolers quality ok??
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2909082
Please Help!
Please Help!Please Help!Please Help!:wave:
i wouldnt be screwing any more boost into it without some better breathing. you need an exhaust, intercooler and pod filter immediately before boosting the poor stock motor.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2911705
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
