Just wondering if this oil is any good? I know you all recommend much more expensive oils but things are tight for me at the moment. The guy at the shop did say this oil was recently compared to Mobil 1 Synthetic and was superior.
Has anyone heard anything bad about this OIL concerning Skylines??
I am draining the shit oil out tomorrow. I have blown no smoke and cant see any leaking anywhere but on the dipstick it is getting lower. I have heard this means the motor does not like the oil it currently contains.
Also what is the model number of the NGK sparkplugs ( the normal plugs) for the 'line and what should I gap them at (I have stocker except for air filter)
Thanks people.
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/
number for plugs is BCPR6E from memory but u should recheck
u can get it from Marlows / Repco and get a gapping tool as well ($2) and gap them to 0.8 coz they come gapped at 1.2
just under 4 bucks for one and havent had any issues with it so far (no misfiring) seems to be doing well
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-314881
yeah my plugs were changed just recently - nissan come out with platinums and a few mechanics will recomend them to u but normal $4 do just as well. :D
Ive got Redline in the Skyline but my 300ZX has Visco in it and i havent had any probs with that oil :)
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-315957
Mobil 1 is tried and tested amongst us so it is the go. Others have their preferences but all go for the well known brand name stuff... So there is something in that.
Plantiums are a matter of opinion. If I change normal NGK R's every 20,000 I am still saving from buying the Platiums.
Your choice.
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-316102
I just bought 5L of visco 5000. The specs look good on paper (https://www.distributor.bp.com.au/wls/servl...?cid=13&scid=14), but the true test is how it works out in real life use.
I've had enough of paying $50+ for Mobil 1, so I'm switching if this stuff delivers the goods. (Unless Strich9ine can get us all a piece of that $35 Mobil action :P ).
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-330061
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
