gillies2001 Posted February 8, 2007 Share Posted February 8, 2007 For 3 months i had a bad miss in my R32 GTR (only happened when engine was warm) I had just replaced the spark plugs,about 1000km (NGK ...6... Iridiums) Then it all started............ CLOSED THE GAP TO .8 ....FITTED NEW SPLITFIRES....CHANGED T.P.S.....CHANGED C.A.S..... CHANGED COIL IGNITER.....CLEANED AND SOLDERED A.F.M,s And then i fitted a set of "NGK BCP6ES COPPERS" "GUESS WHAT, ALL FIXED" Link to comment https://www.sau.com.au/forums/topic/154130-spark-pluggssss/page/2/#findComment-2891447 Share on other sites More sharing options...
gillies2001 Posted February 12, 2007 Share Posted February 12, 2007 .........I also changed the............. COIL PACK WIRING HARNESS ANY THOUGHTS ON THE ABOVE ???? Link to comment https://www.sau.com.au/forums/topic/154130-spark-pluggssss/page/2/#findComment-2899261 Share on other sites More sharing options...
Kinks Posted February 12, 2007 Share Posted February 12, 2007 iridiums warn you on the packet not to adjust the gap, because the centre electrode is very fine and easily damaged. at least you found the problem eventually. Link to comment https://www.sau.com.au/forums/topic/154130-spark-pluggssss/page/2/#findComment-2900655 Share on other sites More sharing options...
_MRR33 Posted February 12, 2007 Share Posted February 12, 2007 http://www.skylinesaustralia.com/forums/in...howtopic=155860 may help if you have a misfire Link to comment https://www.sau.com.au/forums/topic/154130-spark-pluggssss/page/2/#findComment-2900712 Share on other sites More sharing options...
gillies2001 Posted February 12, 2007 Share Posted February 12, 2007 Thanks Kinks, I was having the problem before i adjusted the gap. Yes the centre electrode is very brittle, great care must be taken not to touch the electrode or insulator. Link to comment https://www.sau.com.au/forums/topic/154130-spark-pluggssss/page/2/#findComment-2901510 Share on other sites More sharing options...
