Just what you needed I bet. Good pickup on the dust.
Bearing seizure caused by overtorqueing then?
id put my money on it. Thing is if the rb20 didnt blow, id now have an r32 with an rb20 that ive spent just as much on as i have the rb31det. I awlays intended on upgrades to my skyline...ask Joel :) I was picking his brains just before my 20det blew....:)
I love the 31det and would never go back. Simple as that. Makes power everywhere, and its soo easy to control. No "plant the foot and wait for it"...power is just there when u want it.
As for the interference motor bit....id put all my money to bet that it will happen again with the rb31det if the belt lets go.
could it be that when the belt broke the result was a bent crankshaft sent the valves slightly more southward or the violent shock made the valves open more??? My rb26 is non interface as i have swang the cams around on tdc and nothing hit!!!
Sorry to momentarilly move off topic, but I promised a set of pictures of the R33 mounts and the engine lowering blocks I used. Note that each aluminium mount has had the mounting and locating slots lengthened for positioning on the top of the rubber pad, and the crossmember slot was lengthened from below the pad...Havent dissasembled yet so dont have any actual measurements. The engine/box braces were slightly relieved with an angle grinder to accommodate the power steering lines.
I've been quoted $38 a piston from Jet hot(RB30E forgies) don't forget the valves need to be done to get the full advantage of ceramic coating, SK knows more about this topic.
I rang HPC in brisbane and got a better deal.
It's $198 to ceramic coat the tops and cover the sides of the piston in solid dry film lubricant for a set ($33 a piston).
It's $8.80 for each ceramic coated valve ($211 for one engine)
$3.30 to apply S01 Solid Dry Film Lubricant coating to each valve spring. ($79 for one engine)
seems like cheap insurance to me.
Information is Here
Some trivia about the timing belt Dayco 94407 that most of you guys use.
Did you know this timing belt is also used on factory Audi A4's 1.8L 20V twin cam Quatrro and Turbo 95 onwards(ADP,ADR and AEB engines). Also for the Volkswagon Passat 98 onwards 1.8L 20V twin cam, including turbo (ADR and AEB engines).
It's the same motor in both makes.:cheers:
The forgies finally turned up.
It's an Arias rb30 piston kit, rings,clips and pins included.
It also came with a spec sheet which I scanned and uploaded with the pics.
Stroke 86mm????
Everywhere I have looked it states 85mm. ??
Very nice though.. Thanks for posting. :cheers:
Your right there Joel.
Arias state 86mm stroke and a displacement of 3.035L
In the Factory VL manual it says 85mm stroke and 2.962L
see attached pic.
I'm not too worried about the conflicting specs, measurements will be doubled checked before assembly.
It's the same motor in both makes.:rant:
If you look at the gates timing belt catalogue online.
http://www.gates.com/part_locator/index.cf...ocation_id=3002
For those motors/cars 1.8L, it list 3 different belts, all with slightly different amount of teeth.
Cam. Belt; W/152 Tooth Belt
Automotive Timing Belt T291 Interference engine application
Cam. Belt; W/153 Tooth Belt
Automotive Timing Belt T317 Interference engine application
Cam. Belt; W/150 Tooth Belt
Automotive Timing Belt T306 Interference engine application
I wonder if the shorter ones would allow you to use both lower tensioners, surely two teeth shorter wouldn't make alot of difference to the length?
The dayco belt is 152 teeth.
Any idea as to why the same motor would have different lengths belts available?
This guy used a 150teeth belt and could use the lower tensioners
Timing belt details are - Gates POWERGRIP GT2 p/n 1200 8MGT 30
it measures 1200mm long, 8mm pitch on teeth, 150 teeth, and 25mm wide but it was cut down from 30mm in the factory! Cost $80 as it's a heavier belt.
The problem with that belt is the width and the type of teeth is not 100% correct, but if those Audi's have the correct width and teeth, maybe the shorter belt is better, if its available?
These Audi belts are 22mm wide, whereas the OEM nissan belt is 25mm. Would it be fair to assume it is 12% weaker than the factory nissan belt?
I remember looking into this option, and i think they were either unavailible in OZ or very pricey.
What belt did you use MonstaS4?
The dayco belt 94407?, these are the cars that dayco belt are off?
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
