i've got a pretty heavy one in there now, so i'll keep that in there til it dies then i'm not too sure what i'm going to go for, still want driveability though!
I'll use the rb25 runners and the the rb20 plenum then, that sounds the most practical and easiest.
I'm sorry guys but I can't seem to work out how to search just in this thread. Nor can I seem to download the thread as a whole to search on my computer. And When I go to print view it only shows about 100 posts.
Anyway. I have a couple of questions.
Has anyone done this with a NEO RB25 head yet? Is it possible?
Do I have to remove the strut brace in my GTT to fit this?
It looks like I need a rebuild and I'm keen for some more torque.
EDIT
I found the search this thread button sorry guys. It seems the R34 RB25 head is pretty much the same. Has anyone actually used it though?
Abo Bob,
The Auto would work really well with the auto I think. I had planned on it. UNTIL I changed plans and plan to not use the car as a daily driver once I finish uni, more so a bit of a fun car. Its not worth selling it.
With regards to spool and response.. You would have roughly the same spool/response with the RB30 and a XR6 Turbo as the RB25 with a GCG VG30 highflow setup.
GCG VG30 comes on hard around the 3800rpm mark with the RB25, The XR6 turbo comes on hard around 3800rpm with the rb30, but obviously with more torque and acceleration off boost. The XR6 turbo apparently makes a solid 10psi a shade over 3000rpm. 10psi from that huffer is still a reasonable amount of airflow = power. :D
Linear = traction. :P
Its 100% the way I'm going now. I'm sticking the vg30 turbo on for a few months then at the end of the year will hopefully find a well priced xr6 turbo and bolt it on.
Hope my spool estimates are correct. :)
Edited by Cubes
Stock rods with constant track use would make me nervous at 300rwkw+.
No worse than the rb25. If anything better as the rb30 rod has a better r/s ratio, more leverage (piston weight won't hurt the rods as much) and as there is more leverage there is less rod side load.
The rod fly's up and down the bore straighter. If that makes sense.
Edited by Cubes
Got it.
What about piston speed? That would be increased wouldn't it?
Do you guys use ordinary cast pistons rather than forgies to keep the piston weight down?
Is there any weakness that is shown up by piston speeds that are too high?
I think I know what I'm asking but I might be wrong.
Forgy's sitting on top of a rb25 or 26 rod is worse than one sitting on a rb30 rod.
Piston speed isn't really an issue. Its all about the rod to stroke ratio. :)
The RB30 rod length is 152.7mm
The stroke is 85mm.
Thats a rod to stroke ratio of 1.79. Rather nice. :)
The RB26 rod to stroke ratio is 1.65 from memory.
The mechanical stress is less with the longer rod length. There are two reasons for these results.
The primary reason for these results is that the profile of the instantaneous velocity of the piston changes with rod length.
The longer rod allows the piston to come to a stop at the top of the bore and accelerate away much more slowly than a short rod engine.
This slower motion translates into a lower instantaneous velocity and hence lower stresses on the piston.
Another strong effect on mechanical stress levels is the angle of the connecting rod with the bore centerline during the engine cycle.
The smaller the centerline angle, the less the side loading on the cylinder wall.
The longer rod will have less centerline angle for the same crank angle than the shorter rod and therefore has lower side loadings.
Visualise it. :)
http://www.sportcompactcarweb.com/tech/0104scc_ssbbpart7/EDIT: Here's a nice little link to help.[/url]
At the end of the day the rod to stroke ratio doesn't make 'that' much of a difference to integrity, more so the lesser friction.
Balancing the motor to 2grams or less will also help it hold together better at high rpm.
I've been told usual street performance balance is 4grams, factory 12grams and race 2grams. Mine was apparently done to 2grams.
Unsure if thats overall 2grams or individual as even the smallest nut had been touched. :)
Edited by Cubes
i have a grampa 1 owner 97k engine and it is unfortunatly a S1 block and it doesnt have the oil drain but worst of all it doesnt have the alternative twin cam idler area on the front of the block
I know if you dont have the machined face you can smooth it over with some devcon type of thing (I have the MOROSO epoxy used for building up intake ports etc just for this purpose) but I was thinking of this idea
you know how you drill and tap a new position for the tensioner above the water pump whats stopping you from drilling and tapping a new hole on the other side like my pic
and my engine guy balances my engines to .01 of a gram (ChrisMiltonED)
Edited by DYNOBUSTER
The belt wouldnt be going the way you showed i think. The one below the white one you placed is the std location for the bearing pulley.
If you did that you would end up with the belt running as shown below in my dodgy pic :D
BTW - thats a photo of my motor just after assembly. And while Milton does know his stuff, im glad i chose elsewhere to get my motor done....
ps- for the price a series 2 motor can be picked up for, it will save a lot of hassles in the long run. Jeezus, its like $100 for a short motor...why do people bother using a motor you have to drill and tap, or modify??? :blink:
Why not reverse the location of the tensioners?
Right side up high above the water pump, the left down low?
Interestering you mention Chris Milton Engine Developments, thats who we had do our head.
His price for the bottom end was too expensive for what I wanted.
I was only after a fairly stockish rebuild + a set of forged pistons, crank and rods machined for equal clearances, block crank and rod crack test and a nice heinz balance.
From memory the balance was around $400, thinking back now I'm also pretty sure Andrew sent the bits to Miltons for the balance.
Not too many ppls have heinz balancers.
Edited by Cubes
If you did that you would end up with the belt running as shown below in my dodgy pic :P
ps- for the price a series 2 motor can be picked up for, it will save a lot of hassles in the long run. Jeezus, its like $100 for a short motor...why do people bother using a motor you have to drill and tap, or modify??? ;)
ahhh ok :P
are you serious
and even if you have a S2 block to save you having to get a cam belt made of un-obtainium you have to drill and tap it above the water pump
and if thats a pic of your engine them you have had to drill and tap a thread for the tensioner so sadly you had to dill and tap and modify YOUR block
why the f**k did you bother <_<
and i have a quote to balance the full engine ie flywheel crank piston/rods and harmonic balancer for $180
this is what I have
$55 acid clean
$140 oversize bore
$186 balance
$100 face head and block
$40 micro finish crank
$252 shot peen rods
$108 resize rods (required after shot peening)
$130 ARP rod bolts
$1125 for Arias forged pistons (with moly rings, pins and locks)
$49 ACL race big end bearings
$89 ACL race main bearings
$66 for the cambelt
$240 for a pair of new belt tensioners
so $2580 for the bottom end
thats on the whole bottom end this is what its cost me so far
I was tempted to run a set of eagle H beam rods and I might on the next one I do but I figured the stock rods would be good enough for what I want to do with the engine
ahhh ok :P
are you serious
For starters, any rb30det is going to require another tensioner drill and tapped above the water pump (or the other method). I was referring to drilling and tapping new oil and water lines for the turbo, not the tensioner. Sorry for the confusion, just dont get too upset if you read it wrong. ;)
$66 for the cambelt
Cambelt is only $30 odd, and you can use 2 x rb30 tensioners @ $80 (ie $160 for the pair)
But why should i waste my time if you are going to take offence if i typed it wrong, or you read it wrong....get off it mate, we're here to help everyone. Im no keyboard warrior, ask if you get confused, cos it aint hard....
Our bottom end complete not including bolting the head on set us back $3500 including Wiseco forged.
But then again we did have the crank and rods machined for equal clearances, or what is known as blueprinting those items.
Even still, you consider no forged pistons in your build, ~1400 for a rebuild seems a little too cheap. My bet is you will go to pick up the motor and you will be faced with a bigger bill. Just like Bl4ck32 was when he picked up his head. :(
I remember I received a quote from Miltons, listed what I wanted done and the price was up around 6-7k. ;)
Edited by Cubes
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
