i had a td07s low mounted on a trust manifold, could only fit it withthe rb30 bottom end that worked well, i just changed for a hi mount and front facing plenum
ben...
Did you have any heat related problems. In my engine bay, there's cabling and air-con fridge lines nearby.
What sort of power did you get then compared to now.
Did you keep the TD07S.
Sorry to blast you with so many questions.
Regards.
Edited by conan7772
weally!! no s$^t! and what would that be? you guys must have some idea what your going to use if your building these engines! sheesh! :(
I don't know what your power level would be.
Exactly as I said.. One to suit your power level; being a larger motor doesn't make a difference to exhaust selection.
Airflow = power. Push more boost in to a smaller motor or make it rev higher and yer.. more power so bigger exhaust.
See.. It was a silly question. :D
What is your power goal?
2.5" is generally ok for 200rwkw.
3" for up to 300rwkw
3.5" for over 300rwkw
All though you can still push a 3" to 350rwkw. :(
See.. It was a silly question. :(
All though you can still push a 3" to 350rwkw. :D
Fair enough thats all I wanted a straight up answer we arnt all mechs
I'm far from a mech. Reading and a little bit of visualisation is all I have done.
So... what is your power goal? :)
Sorry didn't mean to come across a smartass,
not sure of my power goal yet, recently blew my RB25DET and i thought instead of just dropping in another stock engine might aswell do the upgrade so Im just asking around to see how much its going to cost me, not in a hurry Ive got another car to drive so probably gonna rip out the old engine and respray the whole car while the new engines being built but just looking at prices at the moment.thanks for your input
ive got some acl bearings here and didnt know they came in oversize. those ones will work and work well, acl are known for their bearings
the acl pistons are actually made by ross in the states so are good also
Just a quick question about the water pumps..
if you use the RB25 one, the bolt pattern is different.. is it just that one bolt hole thats slightly different?
do you just not bolt that one hole? or is there something you can do to get it to fix?
i remember seeing a pic of one with an elongated hole so it would fit both... just cant seem to find it.
cheers
Ok, bit of an obscure question, I am pretty much sold on the rb30det, and I have always loved the shape of the 300zx, I have seen a few pictures of z's with an rb26, so similar things have been done before, but is this a match made in hades? or will it be a case of a few custom engine mounts, bolt up the gearbox, some piping ect... Baisically would it be possible for a backyard mechanic?
Sorry if this question has been answered - I have only read about 60 pages of this thread so far :)
as the manifolds bolt to the head it should be fine. there is a note in the .pdf document that you need to modify the water galleries as they can foul on the manifold. you would need to test fit with your setup to see if this is required.
I read this whole tread a few weeks ago but but didnt bother to read the VCT info. Now I have a few questions as im now looking into an R33 head.....
1. After plugging up the VCT hold and redrilling it and making an external oil feed line etc, where do most people attach it to the block?
2. do aftermarket cams work with VCT?
3. Does the R32 RB25 head need extra bits welded on it to give more metal around the coolant galleries or is this just the R33 VCT?
Thanks,
Matt
Just buy a brass fitting a kind of t-piece (which in reality is just a cylender with a thread in the side) from VDO.
It will screw into your block where the oil pressure sender goes, you hook that into the end of the fitting, and use a bit of braided line to run a feed to the head.
Some aftermarket cams work with vct but they are very expensive.
And no the rb32 head doesn't need extra welds at the front.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
