I got a ride in Macgyers(StockyMcStock) car today.....woot for me and him and his twin charged car....it is the shit i tell you. The rain was lame though.
Jealous Cubes??? :(
lol....
What did you think of the diff ratio in the VLT paired up with the 3ltr compared to your 4.11's? :pirate:
Just a tad long or?
yeh it did seem to stretch out abit more then the skyline....but the power delivery is like nothing ive felt before......we were like 3rd gear 1500rpm and he goes like half throttle and then bam its like a jet turned on and were doing 80 from about 30km/h....fricken awesome so much more power down low and only from 9psi. Lots of wheelspin, but it was raining this morning so it was hard to get a real appreciation of the power and acceleration. Will definetely hit him up for a ride one day in the dry hehe :pirate::(;)
Also just a side note the car is the biggest sleeper....looks like your average commo all stockish looking just lowered. The only give away is the fmic and piping. I spose the massive whine from the blower might be a tad suspect...then the screamer well hell once that goes off then you know it aint some stocko commo.
Edited by r33_racer
your lucky it didnt have nice neat holes oiut the side of the block sorry to here lad.
all the ppl saying check your clearences ect if there not rite from the initial build it wouldnt have lasted this long and would have shat along time ago
the oil presure blead that he spoke of would have taken the top layer of bi-metal off and things can only get werse from there in a high power situation.
the poor litle berings would be geting a fair bit of force put on them each power stroke taking more metal off each time.
look on the brite side (if there is 1) you can fix any of the things u have wanted to change.
Pretty basic question -
Are the standard issue rb25 spark plugs suited for the rb30det?
Asked about them at repco, and they want $27ea for platinum "oem" sparkplugs, sounds a bit rich to me (used to paying about that for a set of 6 haha). :)
Hey michael, thanks for lettin me have a squiz at the racecar, top piece of work there. MAKE SURE YOU ASK ABOUT THE OPEN-COLLECTOR, SPLIT PULSE HOUSING DILEMMA! i want you to make an informed decision on the thing before putting it on your engine. it's an expensive piece of equipment, that new turbo. see what the experts have to say about it. at the very least, it won't be optimal for gas acceleration and turbulence through the housing. at the worst, it could melt your scroll separator bar and put bits of molten metal through the turbine wheel. just something to think about :)
definately need to take you for a ride in the dry, you can't really appreciate a twincharge otherwise :sick: don't worry it'll be tuned for 300kw soon, that will be more fun i promise. not quite as spastic as your racecar though.....
platinum - standard plugs are fine man. i use and recommend Cheap Shit Plugs®, they are doing fine so far.
edit: because i'm anal, i collected some quotes for ya:
The reason that you don't use a split turbine on an open collector is basic airflow and HP. Because of the design of a manifold, the airflow directed at the plate is never even, even in my manifolds, which are as symetrical as physically possible with the merge collector, with the gas directed at an agle accross the face of the split, the air can't make a decision which side to go up. This is probably a bad example of what I'm trying to at, but basically, the air is turbulent, and in most instances (as in not very well designed manifolding) the air will try and be forced more to one side of the split, effectively halving the cross sectional area the exhaust gas tries to pass through, kinda like putting a tiny rear housing on your turbo.
One of the companies i deal a lot with that has a 8sec turbo hemi, has tested many different turbos and housings over the years, and picked up 72rwhp and 9 MPH just by changing from a 1.32 split rear on his P trim T66 to a .96 single entry on his single entry manifold, as the .96 is smaller in equivelent size, so all of that power was due to better gas flow, it also picked up 900rpm of spool up time. Basically, airflow will never be even in a divided housing, with an open collector.
6BOOST
okay so i can't find any more cause i suck at the internet. just ask around and see what the "experts" say.
Edited by StockyMcStock
Well the oil pump was opened up and checked out and its all good and in one piece. So cant blame the N1 pump for this one. Further inspection has revealed the girdle is cracked around no.6 piston.
Well were stripping down another rb30e long block tonight to get it machined asap to put together this new engine. Two weeks to do this. Gonna be hectic :)
was no.6 piston the one that spun the bearing? is there some way u can crack test the girdle, like u do a crank etc?
When I had the bottom end of mine crack tested the engine builder pointed out a few spots on block, rods, crank and girdle where they tend to crack if they do at all.
I think in r33_racer's experience it was just pure bad luck. :)
no.6 did and 5 with 6 being worst. But it cracked around 6 because as everyone knows 6 always runs the hottest. But weve put it down to a definete oil surge issue that started all this a few races ago. We thought we had gotten away clean but we didnt :) So dry sump now, so no more oil issues.
Yup bad luck, but thats motor racing for ya :)
We can rebuild it. We have the technology. The next rb30 will be better then before. BETTER, STRONGER, FASTER!
Good to hear it wasn't the Oil pump, was a little worried. I can assure you I have everything crossed for my passenger ride at QR :) . Good luck with the rebuild mate. Onward and upwards.
Hey everybody,
just got rb25/30 combo dropped in my car, it has been freshly rebuilt with forged WISECO pistons, has heavily ported head and it made 414rwhp at 18psi with ITS 57 turbo which is equivalent to GT30 I think, now it made a lot of power, it uses standard head gasket but did compression test after maybe 1500km and it has compression ratios between 110-115psi, is that too low even for wiseco pistons? I was told it is built for 8:1 compression ratio but this compression results seem low? It has VCT setup as well. Anyone used WISECO pistons on here and what is compression on their engines?
I think you used the wrong wiseco pistons.
Possibly the pistons they list for the RB30DET that yield a comp ratio that is simply way too low. From memory they achieve a comp ratio of around 7:1.
I used the RB25 wiseco 87mm pistons with a 14cc dome and cometic 0.55" head gasket. With that combo I've got just over 160psi in all 6 when the motor is warm. When cold its just under 160psi. And awesomely.... after 45,000km's all cylinders are the same except for cyl 3 thats a whopping 1psi down, the last comp test it was the same but the motor was tested only when cold. :)
I'm stoked with how even the comp test came out.
I used the RB25 wiseco 87mm pistons with a 14cc dome and cometic 0.55" head gasket. With that combo I've got just over 160psi in all 6 when the motor is warm. When cold its just under 160psi. And awesomely.... after 45,000km's all cylinders are the same except for cyl 3 thats a whopping 1psi down, the last comp test it was the same but the motor was tested only when cold. :whistling:
so the one you used cubes was the one 3rd from the bottom
not the bottom one
here
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
