Regardless more than 7.5k and u really should be running an aftermarket balancer.
So its either you go all out or you don't.
Standard rods resized with new bolts.
Price up what you want done to the std rods and then compare the price to spool import forged rods and you will see why its useless spending $$ on the stock rods.
has any one tried their luck with grabbing their series 2 motor from a wreckers then slappping the head on with new head gasket>?
like not touching the rings or bearings in the bottom end???
I know a couple of guys who have whacked together something rough and cheap, seems to be working fine for them pushing decent power? You looking into doing it yourself?
its just an idea at this stage as my motor seems rather heallthy...
the factory hone marks are still looking good.
i was thinking of putting rb30et oil pump and that being the only real change to the bottom end..
will be chucking in head oil restrictors also...
im havingtrouble finding any place tha can suply the tomei press fit oil restrictors...
what kinda of power figures are your mates cars running???
im running a hks T04e turbo.. i cant imagine it flowing enough to get anything over 270rwkw..
ill be happy to get over 200 at the wheels..
i have just brought dahtone racing (from this forum) head from his 32 which has been ported and running gtr valve springs..
all i would be buying would be genuin head gasket a idler and a genuine water pump and thermostat....
oh reallly..... maybe not such a good idea with the restrictors aswell as the 30et pump??
wat pump would you suggest going with...
my other thought was a rb25det pump....
was not sure if you needed the crank collar if you went with the series one oil pump???
cheeeers
cheeeers
yeh i would suggest the rb25det oil pump few of the guys suggested that to me also. you should get 200 at the wheels easy just whacking it together, some guys on the forums are talking fairly big numbers, but even saying that iv been told the factory bottom end can hold upto 500hp.
I saying that say you spend 1g max putting the 30 together on a very cheap its not gonna hurt as much as spending 5-6k and blowing it up right?
you should use a thicker gasket maybe?just an idea but im planning on using a multi layer rb26dett.
Im planning on using restricters with the 25det oil pump? Is this right/wrong?
Edited by Redliner007
Why not to use an RB30 oil pump... well it's just a bit skinny. Restrictors will be good with the 25/26 pump. Don't need to drop the CR at all so just use a single factory 25 head gasket. The collar is a damn good idea, and Nissan eventually made it standard across all RBs I know of after the 33GTSt and later model GTR32s to give a wider oil pump drive.
thanks for the offer geoff....but dad ended up getting a whole 26 head the other week anyway. So i need to change that sig now lol...Even so, we wouldnt have needed the idle control anyway...race car we just do it manually...one less valve, less weight and clutter :thumbsup:
what about leaving the stock rb30 oil pump and not running any restrictors or anything????
i planned on just using a stock nissan rb30 head gasket...
its my understanding that to fit the crank collar the crank has to be removed from the block and fitted professionally, is this correct????
cheeers
ps just ordered my dayco timing belt threw repco, cost me $60 cuz they had to order it..
what has anyone paid for a genuine rb25 idler???
haha yep ripco for sure ay...
spewing. as their is also a sprints in my town too...
oh well repco is just a pushy ride away and already paid for...
where abouts can ya purchase the head oil restritors??
yeoooowww
anyone got a spare rb25 idler sitting around??
haha
I would presume the stock rb30 pump should be ok with stock restrictors.
I remember some one on ct.com had issues with pressure bleeding off on idle with the rb30e pump. Unsure if it was a stuffed bottom end, pump etc.
Wouldn't use an idler. Use 2 x tensioners.
oh okay rekon i go with two tensioners.... its best to determen where to drill the hole for the second one after you have your timing belt?
so to get the right tension kinda thing??
salesman and a half you are dahtone.. haha im already in debt to ya..
does crank need to be removed to fit the crank collar??
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
