I would presume the stock rb30 pump should be ok with stock restrictors.
I remember some one on ct.com had issues with pressure bleeding off on idle with the rb30e pump. Unsure if it was a stuffed bottom end, pump etc.
Wouldn't use an idler. Use 2 x tensioners.
someone on here also had issues when they reused the stock RB30 oil pump, had to replace it with a twin cam one.
alright sweet..... hmmmm
should be okay to just use the stock rb30 tensioner and the tensioner off my rb20 aswell....
sweeet as chhheeeers for all the help
why not replace the old tensioners? you should be able to pickup two brand new ones for sub $100.
yeah i was just thinking that.. i remember hearing tensionsers are f**k all any ways..
when i order thermostat head gasket water pump and now two tensioners :banana:
was their somthing i red in this thread about series one rb25 oil pump works fine without the collar.. as its the same length on the series one rb25 crank???
any confirmation?
does anyone know max recomened boost and max rwkw on stock bottom end?? (new rings, bearings and a hone)
like with stock rods and pistons..??
heard of guys going over 300rwkw on stock na pistons and rods.....
:worship:
got qoute for $1800 for acl race series bearings, new rings, crank collar supplied and fitted and all new welch plugs and seals
is that the average kinda price range for that work to be done
cheers
tom
has anyone got the torque specs for stock rb25 head bolts? can these bolts be reused? how much is a new set if they cant?
this is a super budget build for abit of fun, i dont care if it doesnt last ages, i dont wanna spend money if i dont have to, limiting the power to 400hp anyway so shouldnt be too much stress. :whistling:
this is a super budget build for abit of fun, i dont care if it doesnt last ages, i dont wanna spend money if i dont have to, limiting the power to 400hp anyway so shouldnt be too much stress. :huh:
you can re-use them, but i dont know the torque specs off the top of my head, someone else will probably chime in :D
although ARP head studs arent all that expensive
Edited by R34GTFOUR
thanks guys great help, i got hold of some second hand rb25 bolts yesterday for $20 so ill see if they last, if not i dont care ill just get some new ones.
the motors coming together nicely now, its a basic setup using a stock rb30 bottom end that i bought from a mate for $50, pity it was a s1 block :P
The block has been recond as it has acl main bearings and NDC rod bearings, these are stamped with what i beleive to be the date they were made and it says 1998 so its still fairly old, hopefully they last a while. I had to tap the water feed for turbo, and drill out the oil feed line as well. I then got the machine shop to deck the block and wash it and tap the oil drain for turbo as well all for $100. I bought the front and rear crank seals for $16 for both, and a dayco timing belt for $31. I decided i didnt wanna tap the head bolt holes for rb26 bolts as the plan is to chuck in stock bottom ends if this blows up and i dont want to have to retap bolt holes everytime i buy a bottom end. So the plan is to use some stock rb25 headbolts as mentioned. I bought 2 mig welder tips for $1 each and used a 1.5mm one in one feed and the other one i welded the hole up and put in the other feed, worked perfect.
I bought a low comp rb26 complete a while ago, i removed the head for this project and had the head decked and valve seats recut as the motor had been detonating and the seats were shocking condition. I chucked in some new valve stem seals and the valve guides looked brand new and were within specs.
I am putting this into a 32 gtr running rwd (using the rb30 sump) and machined off front axles, plus either a gtr box with removed tf case or a rb25 box. I have bought a t3 flanged high mount manifold for $200 from a mate, its a steampipe design and looks great, definately got a bargain, it was used on a rb26 with gt3540 xr6 turbo internal gate turbo, so i need to add an external gate pipe on it or run an internal gate turbo.
I think a gt3076r is my number one turbo option, i have the injectors, ecu, fuel system all sorted from my current setup and hoping to push around 400rwhp, the gtr is stripped out and should be at 1250kg or just under with the 4wd stuff removed and totally stripped.
post-40430-1219243495_thumb.jpgpost-40430-1219243531_thumb.jpgpost-40430-1219243593_thumb.jpg
Why? :S
Finally got it tuned!!!! Feels really nice to drive
Unfortunately maxed out the Z32 for some unknown reason so couldnt go any further as i only had 2 hours of tuning available on the dyno with DrDrift
Just wondering if anyone can tell me what this works out to be in NM?
Posted up the full setup and other graphs in the dyno thread: http://www.skylinesaustralia.com/forums/in...t&p=4082856
Edited by dano4127
Strange you max'd it out at 255rwkw. Mines pushing ~5volts at 302rwkw.
Boost leak?
Thats what im hoping! Couldn't find an odious one but i will do some detective work next weekend
A mate of mine has a bung and compressor so I will pressurize and see what we can come up with...
Nice work Brad and Dan! hopefully I have some big number to post soon :)
:thumbsup:
Finally fired the new machine into life with a slightly strange situation, Im running N1 pump, 26 head with 2 x 1mm restrictors. The strange part is I have fitted a mechanical autometer oil pressure gauge off the main gallery where the original RB30 oil pressure sender screw into & it gradually goes off the chart to 100psi at idle..... Im running 15/40 shell helix mineral oil, the std oil pressure gauge on the dash reads about 3/4. Not sure if I have an issue with the oil thickness or a bodgy gauge....
Anyone else had this?
I havnt fully warmed it up yet as still fitting the wideband sensor & want to make sure all is good
Cheers, Matt
Why? :S
because i can :( nah its because i want a cheap setup for drifting and then i have the 560hp at wheels rb26 engine for proper track work and a ppg dogbox, i will swap between the 2 setups in the gtr :P im trying to save weight with the 30 setup as its gonna be limited to 400hp and it will pretty much be like a gtst setup drivetrain wise with this engine.
because i can :) nah its because i want a cheap setup for drifting and then i have the 560hp at wheels rb26 engine for proper track work and a ppg dogbox, i will swap between the 2 setups in the gtr :( im trying to save weight with the 30 setup as its gonna be limited to 400hp and it will pretty much be like a gtst setup drivetrain wise with this engine.
thats cool but fark your a gluten for punishment!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
