Mine does 100km/h at 3875rpm.
So the calculation is pretty spot on given the R33's have a higher diff ratio.
Thats pretty insane really thinking that he is making at 3500rpm what I am making at 7000rpm and the funny thing is I also have more lag!
wahahahha.. :)
I noticed the inlet valves are quite large.
They basically fill the while side of the chamber.
Would be hard to fit larger ones unless you were to move away from circle valves.
When I get the RB20DET out i'll take photo's of its head and show compare photo's with the RB25 head.
had to travel 1000+ks but it was worth it,
280hp at wheels with 14psi boost(did see peak 300hp but dyno sheet says 280)
for those who dont know i have bolted the 25t head onto a rb30 na bottom ,im still running the 25t ecu,turbo,injectors,intercooler,etc
mobs are simply K&N pod full 4inch exhaust and elect boost controller
had problems with my original bleed valve making spikes up to 17psi and causing boost cut had to buy and fit a ebc
fuel mixtures were fine, still running rich at full boost though ,obviously the 370cc injectors are up to the task
the only thing that caused concern was the timing having to run at 27deg advance to preform ,this had the dyno mech rather confused ,a few degrees more and detonation was heard
SYDNEY KID/ Anyone do you have any idea why the hybrid has to run so advanced to make power do i need adjustable cam gears?????
all the same ,im very impressed with the cheeap hp, sure beats forged pistons/aftermarket ecu on cost
cheers
Depends on the wheels he is running.
Mine does 3875rpm at 100km/h and at 3500rpm its doing 95km/h.
I just worked it out with a 4.11:1 diff ratio and it is 3500rpm at 100km/h.
This is using stock wheel sizes.
Remember we are going off a Dyno printout here and it won't be accurate.
i.e 100km/h on the rollers isn't going to be 100km/h on the road.
Ahh close enough then.
BTW, changing the wheel size won't do anything to change what your speedo says at any given engine RPM.
I would have thought that the dyno would have been more accurate at telling actual road speed than any car speedo because wheel size would not be an issue (but the speedo would read wrong if you changed wheel size, which would throw out any calculations based on dyno speed)
Wheel size does make a difference what your speedo reads.
If you run a small arsed 13" wheel your spedo is going to be saying that you are doing 130km/h when you are only doing say 90km/h.. .:D
But yer.. I would have also thought that a dyno would have been more accurate BUT.. when I had mine done it was way off with the speeds.
"If you run a small arsed 13" wheel your spedo is going to be saying that you are doing 130km/h when you are only doing say 90km/h.. "
Yeah, but your tacho will still say 3500rpm (or whatever) when your speedo says 100km/h (in the respective gear). You could throw your wheels taishaft and diff into the ocean and that would not change :D
doesn't matter what size wheel you have, as long as the profile tyre is right. You can have a 19" wheel with a 20 profile tyre (if they exist), and that will be the same diameter across from tyre edge to tyre edge as a 15" wheel with a 90 profile... i know these aren't exact, but i'm just using them as an example. If you had a 19" with a 30 profile and a 15" with a 30 profile then the diameter's of each wheel from tyre edge to tyre edge will be different.
Thats true Gijor33.. BUT.. I had 16" 225 50' VR GTS 16's on my VS commodore. When I went to slap the spare on the arse end it was slightly higher. It wasn't much (1.5-2cm's) but it was enough to cause the car to steer left when accelerating and steer right when decelerating.
Who really matches their new wheels up to the standard sizing. Not many if any :D
Hey all.....
First of all, Excellent Thread. BLOODY TERIFFIC MATES.
After reading all of this thread i have come to the conclusion that the series 2 commondoor block is the best for the conversion as it has all the oil/water inlets and returns and what not, for the turbo applaction...
Now my QUESTION is, how do you tell the difference between the series 1 & series 2 blocks????????
I live in brisbane, so some of the wreckers up here are a bit dodgey and would prob try and sell me a series 1 block if they did not have a series 2.....
SOOOO it would be good to be able to tell the difference betwwen the 2.
Thanks in advance people ;) ;) ;):D;)
i am chasing 250rwkw+ to get my boat moving.
I'm wondering how much power the stock pistons(NA VL) will cope with before they explode. Would the strength and longevity/power produced be increased by cryo/heat treating the stock NA pistons?
*i have gone back thru the thread to look for my answer too :D*
I have read the entire thread and would like to ask a few questions:
1. Will the engine fit straight into the engine bay or will there have to be modifications of engine mounts etc etc?
2. If this conversion is so easy and the end result a powerful engine....why didn't Nissan ever develop and include the RB30DET in one of there cars?
Cheers.
Pistons longevity is probably more related to tune than outright power.
I would think that if you can make that sort of power with an RB25DET on stock (9:1 CR) internals, an RB30 with RB25 head and NA pistons would be just as easy to achieve as the CR is a bit lower, therefore less prone to detonation - which is the real enemy of the pistons, not power.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
