AND... If and when you crack test the rods if one is bung you can find another second hand for around $20-$30 AUD.
When I was in Nissan the other day picking up some parts I asked how much as new Nissan RB30E bare block is new.
$2500... I remember that new nissan block that was on sale here in SAU not that long ago for $500. That was a bargain.
Joel when are you updating your DIY RB30DET guide? I would like to know about using the original turbo off a RB25 (r33 / r34) and have about 5 to 10 psi. I would still want a compression ratio of about 9:1... or would it be better to use a different turbo and just sell the other? I dont mind spool up at 2500 - 3000 rpm, I just don't want spooling earlier or up at the 4000k mark... I'm not after high boost either. How about twin turbo, where one spools up and at a certain amount of rmp the other one kicks in...
I will update it when I get my hands on my parents digital camera next.
Using the std rb25/30 turbo apparently spools to full boost around 1800rpm. So basically you wont feel any lag.
If you were to have a turbo that spooled up to full boost at around 4000rpm then you would be making over 300rwkw.
A GCG stage 2 500hp turbo makes full boost around 3000rpm and makes around 250-260rwkw on 1bar with the RB30DET. On a RB25DET you can add another 500rpm approx until it is on full boost.
You don't want twin turbo where one spools then the other spools at a certian RPM it is to much trouble.
Well i'm going with a Garrett GT30 with a .82 exhaust size... Its rated to 600hp... ;)
Should be getting the ball rolling within the next week... Going to start building the head (its in millions of pieces atm)... Going to fit some big cams (270deg 10.8mm lift) into the 26 head...
Oh yeah just a question... Anyone know where i can get big sumps for RB engines??
It was late last night when i posted that, so i've just begun looking, just thought i would ask if anyone knew anywhere they made/imported/resold sumps...
I'll looking at spending as little as possible... ;)
Thanks Sciby i'll try them and see how i get on...
I'm getting the RB20DET sump baffled.
If you do the above as you said you can easily kiss around 10k good by if you already have a full exhaust and suitable intercooler. If you havn't then its going to cost approx another 1.5k for a suitable intercooler and say 1.2k for a decent exhaust.
i.e
RB30 short motor with forged pistons & shotpeened rods - 3500
Injectors - 900
Aftermarket ECU & Tuning - 2000
Custom Exhaust Manifold - 1000
Wastegate - 800
Turbo - 2400
Total - 10,000
+ Fitting and other little bits
Joel, i thought we went through this already...
I've got a new block which will be bored out to 87mm with Arias forged pistons and Argo forged Con Rods and standard crank...
N1 Oil and Water pumps...
RB26 head with Tomei 270degree step 2 cams, springs and sprockets...
ATi fluid dampener...
Tomei fuel rail...
As well as a few other bits and pieces...
I already have Autronic Sm2 v1.93, intercooler, turbo, wastegate, manifold and all that stuff...
Thats right I was refering to your comment on spending as little as possible.
Which really is not possible as you have basically selected everything for the motor that is going to make you spend as much as possible.
Hence the RB26 head, Tomi Cams, Tomi Fuel rail (that is not really needed) and especially the Autotronic ECU.
Personally speaking, when it comes to projects like this... unless you've got scads of cash and no full time job, you can't rush it.
I know I can't... money is tightish (trying to buy a house), and I don't want to cut a corner, just to find that I've wrecked what could have been a powerful, solid, reliable engine.
Slow and steady gets the smaller quartermile times. :P
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
