AND... If and when you crack test the rods if one is bung you can find another second hand for around $20-$30 AUD.
When I was in Nissan the other day picking up some parts I asked how much as new Nissan RB30E bare block is new.
$2500... I remember that new nissan block that was on sale here in SAU not that long ago for $500. That was a bargain.
Joel when are you updating your DIY RB30DET guide? I would like to know about using the original turbo off a RB25 (r33 / r34) and have about 5 to 10 psi. I would still want a compression ratio of about 9:1... or would it be better to use a different turbo and just sell the other? I dont mind spool up at 2500 - 3000 rpm, I just don't want spooling earlier or up at the 4000k mark... I'm not after high boost either. How about twin turbo, where one spools up and at a certain amount of rmp the other one kicks in...
I will update it when I get my hands on my parents digital camera next.
Using the std rb25/30 turbo apparently spools to full boost around 1800rpm. So basically you wont feel any lag.
If you were to have a turbo that spooled up to full boost at around 4000rpm then you would be making over 300rwkw.
A GCG stage 2 500hp turbo makes full boost around 3000rpm and makes around 250-260rwkw on 1bar with the RB30DET. On a RB25DET you can add another 500rpm approx until it is on full boost.
You don't want twin turbo where one spools then the other spools at a certian RPM it is to much trouble.
Well i'm going with a Garrett GT30 with a .82 exhaust size... Its rated to 600hp... ;)
Should be getting the ball rolling within the next week... Going to start building the head (its in millions of pieces atm)... Going to fit some big cams (270deg 10.8mm lift) into the 26 head...
Oh yeah just a question... Anyone know where i can get big sumps for RB engines??
It was late last night when i posted that, so i've just begun looking, just thought i would ask if anyone knew anywhere they made/imported/resold sumps...
I'll looking at spending as little as possible... ;)
Thanks Sciby i'll try them and see how i get on...
I'm getting the RB20DET sump baffled.
If you do the above as you said you can easily kiss around 10k good by if you already have a full exhaust and suitable intercooler. If you havn't then its going to cost approx another 1.5k for a suitable intercooler and say 1.2k for a decent exhaust.
i.e
RB30 short motor with forged pistons & shotpeened rods - 3500
Injectors - 900
Aftermarket ECU & Tuning - 2000
Custom Exhaust Manifold - 1000
Wastegate - 800
Turbo - 2400
Total - 10,000
+ Fitting and other little bits
Joel, i thought we went through this already...
I've got a new block which will be bored out to 87mm with Arias forged pistons and Argo forged Con Rods and standard crank...
N1 Oil and Water pumps...
RB26 head with Tomei 270degree step 2 cams, springs and sprockets...
ATi fluid dampener...
Tomei fuel rail...
As well as a few other bits and pieces...
I already have Autronic Sm2 v1.93, intercooler, turbo, wastegate, manifold and all that stuff...
Thats right I was refering to your comment on spending as little as possible.
Which really is not possible as you have basically selected everything for the motor that is going to make you spend as much as possible.
Hence the RB26 head, Tomi Cams, Tomi Fuel rail (that is not really needed) and especially the Autotronic ECU.
Personally speaking, when it comes to projects like this... unless you've got scads of cash and no full time job, you can't rush it.
I know I can't... money is tightish (trying to buy a house), and I don't want to cut a corner, just to find that I've wrecked what could have been a powerful, solid, reliable engine.
Slow and steady gets the smaller quartermile times. :P
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
