the solenoid will have to be wired up to an output driver of the wolf.
i have an EBC solenoid wired into an output of my EMS and i control boost by changing values on the Pulse Width Modulator (PWM) value. Its pretty much just a way of tellin ghte valve when to open and what KPa to regulate boost to.
One side of the solenoid will go to +12v, the other will go to pin 5 (red/white) on the Wolf. I think you also need a diode across the solenoid to prevent damage to the Wolf, so it would pay to check the install manual.
The PWM frequency needs to be matched to the solenoid being used. I have a haltech solenoid which operates at 33Hz. You can change the solenoid opening amount every 500RPM.
Not sure on the hose hook up. I've heard people say the bottom port is always connected to the inlet manifold and the solenoid is connected from the inlet manifold to the top port of the wastegate.
for those of you going front facing plenums,
i'm looking at gradenko and Bl4cK32 here (the only ones i can remember off the top of my head)
What are you doing for an accelerator cable?
i have been told to get an s14 cable... is there any difference between an s14 and s13 cable?
and for those putting RB25DET 5spd into R32's... how are you combatting the speedo sender problem?
i've found this which may be suitable.. but i'm sure someone on here with more knowledge will shut me down... ie SK :)
Stolen from Calais Turbo: http://www.calaisturbo.com.au/showthread.p...ighlight=navara
Nissan Navara speedo sender. Total cost of ~$23
One thing i'd be concerened about is the ratios of that gear. But the VL guys seems to use that in their MX7's and RB25det 5spds.
its easy people, buy a gtr 32 speed sensor, remove the 33gtst one and take the gear of the end, put the gear onto the 32 one and put it in the gearbox and screw on the speedo cable
Clint,
Hows the spedo read with the 4.363:1 R32 GTST rear gears?
R33 Cluster will not fit into the R32.. unless you make it fit.
I think electric is easier, as an auto elecrtician can always make the signal work, and convert it to MPH quite easily. Can also be setup exactly right for your tire size and diff etc.
Could always just do a complete custom cluster setup..
hey guys looking for info on putting an RB30DET into an S13 Silvia. my clutch and starter motor recently died so while its out of action i thought i might put a turbo engine into it and i had this engine lying around doing nothing anyway. Im after parts ill need and also anyone near springwood, brisbane that can do such a conversion, and possibly a price. i know its not the best choice of engine but seeing as i already have the car and engine it works out to be the cheapest.
ill also need info on documentation ill need (ie. mod plates, engineers certificate, etc.) thanx for any help
Didnt i tell you to read the entire thread first ??
GTR-Ben may have some info for ya.
Thats my concern, you hear all the Nizpro guys producing great figures and doign great times, but are the engines hand grenades, are they durable etc. Ppl have a tendency to keep to themselves when they have a failure
This comment has got me thinking...
We hear of lots of people building these motors but not many who have been driving for some time.
I have heard of people who had these engines (rb30det) but wont say why the engine no longer exists.
SK has stated in the past that the R32 GTR oil pumps tend to fail with hi rpms and rb30's have trouble with oil temp.
Is there anything else we should know? I don't want to have to learn the hard way after spending the $$$. :P
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
