SK , I like the idea of the RB26 head . Better cam profiles , larger valves (by how much I don't know) better and lower inlet manifold , common injector style . Was the RB26 head difficult to come by , obviously it was not cheap . I assume it can use the single turbo exhaust manifold plus coils and ignitor .
Thanks SK , A .
They'd be of interest if you own a 240Z/260Z, 280zx, 1600, Z31, DR30, or import R31.
Basically the newer R200 found in later skylines is too short for our cars.
Back on topic though, so with the 3.0L is worth dropping to say around a ~3.5 LSD you think without harming accceleration?
Would probably sit on nice low revs on the freeway I suppose.
looks at my signature:
HR31 GT Passage Skyline
i think i've got 4.4's as my car was once auto and i was wondering how they would affect the 3L and its power out put. I think the 4.11 and 4.4's are in place to make the non torquey RB20 feel punchy and quick, but what will happen once the 3L with mountains of torque goes in? will the tires light up too easily?
:D
it sits nice and low in the rev range with the std r32 4.3 lsd....dont worry about extras unless its a) got to be sorted in a custom job (like drukenmaster), b)your old diff is rooted.
I always see people asking about big arsed turbos, injectors etc....how about people worry about building the motor, fitting it and getting it running......
I will be fitting my solid fuel lines down the length of the car tonight, followed by the adjustable suspension during the week. Now it is easier to fit the diff and the rear suspension at the same time as they share mounting points, and I need to fit my new suspension in order to fit my modified front crossmember. Now the front crossmember will need to be in so I can fit my modified engine mounts to it, and those mounts will have to be there to sit my RB30DET on.
So sorting out a diff for me to pick up now is crucial to getting my RB30 fitted and running :wassup:
:jk:
Drunkenmaster , later I will look into a 3.7 or 3.5 ratio long nose R200 . Going from 2 litres to 3 should pull this easily . From memory VL's used a 3.45 std with a 3.3 1st gear (NA) .
Be careful, VL's came with 185/60/15's, compare that to my GTST with 245/45/17's, this turrns the 4.363 dif ratio into a 3.9. :)
Can someone tell me what valve sizes in RB26 and if ports/stud patern on exhaust side same as RB20/25DET .
No, this is like Groundhog Day. Nissan don't want you swapping GTR bits onto cheaper cars, so they designed it so it was different. :)
Hi,
I'm new to the forum and must say that this thread is oustanding, credit goes to everyone who has contributed.
I recently picked up a r33 GTST with a blown bottom end and after reading this thread i know what bottom end i'll be using.
I have purchased a GT3040 (0.82 exh ) to go with the new engine.
I have a question.
What parts will fit into the RB25DET head from a GTR head?, I have read in another thread that it's possible to use GTR cams in an RB20.
I got my block last week and after removing the head gasket noticed that there was a '2' stamped on each of the pistons and next to each cylinder on the deck. Is this an indication that the cylinders have been bored? The hone in the cylinders is pretty good considering the engine has 200,000k on it
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
