SK , I like the idea of the RB26 head . Better cam profiles , larger valves (by how much I don't know) better and lower inlet manifold , common injector style . Was the RB26 head difficult to come by , obviously it was not cheap . I assume it can use the single turbo exhaust manifold plus coils and ignitor .
Thanks SK , A .
They'd be of interest if you own a 240Z/260Z, 280zx, 1600, Z31, DR30, or import R31.
Basically the newer R200 found in later skylines is too short for our cars.
Back on topic though, so with the 3.0L is worth dropping to say around a ~3.5 LSD you think without harming accceleration?
Would probably sit on nice low revs on the freeway I suppose.
looks at my signature:
HR31 GT Passage Skyline
i think i've got 4.4's as my car was once auto and i was wondering how they would affect the 3L and its power out put. I think the 4.11 and 4.4's are in place to make the non torquey RB20 feel punchy and quick, but what will happen once the 3L with mountains of torque goes in? will the tires light up too easily?
:D
it sits nice and low in the rev range with the std r32 4.3 lsd....dont worry about extras unless its a) got to be sorted in a custom job (like drukenmaster), b)your old diff is rooted.
I always see people asking about big arsed turbos, injectors etc....how about people worry about building the motor, fitting it and getting it running......
I will be fitting my solid fuel lines down the length of the car tonight, followed by the adjustable suspension during the week. Now it is easier to fit the diff and the rear suspension at the same time as they share mounting points, and I need to fit my new suspension in order to fit my modified front crossmember. Now the front crossmember will need to be in so I can fit my modified engine mounts to it, and those mounts will have to be there to sit my RB30DET on.
So sorting out a diff for me to pick up now is crucial to getting my RB30 fitted and running :wassup:
:jk:
Drunkenmaster , later I will look into a 3.7 or 3.5 ratio long nose R200 . Going from 2 litres to 3 should pull this easily . From memory VL's used a 3.45 std with a 3.3 1st gear (NA) .
Be careful, VL's came with 185/60/15's, compare that to my GTST with 245/45/17's, this turrns the 4.363 dif ratio into a 3.9. :)
Can someone tell me what valve sizes in RB26 and if ports/stud patern on exhaust side same as RB20/25DET .
No, this is like Groundhog Day. Nissan don't want you swapping GTR bits onto cheaper cars, so they designed it so it was different. :)
Hi,
I'm new to the forum and must say that this thread is oustanding, credit goes to everyone who has contributed.
I recently picked up a r33 GTST with a blown bottom end and after reading this thread i know what bottom end i'll be using.
I have purchased a GT3040 (0.82 exh ) to go with the new engine.
I have a question.
What parts will fit into the RB25DET head from a GTR head?, I have read in another thread that it's possible to use GTR cams in an RB20.
I got my block last week and after removing the head gasket noticed that there was a '2' stamped on each of the pistons and next to each cylinder on the deck. Is this an indication that the cylinders have been bored? The hone in the cylinders is pretty good considering the engine has 200,000k on it
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
