Hi all.
The time has come..
R32 Skyline GTST
1992 Manual.
Everything power.
Interior:
Autotechnica Steering wheel
Impul Gear Knob
Autometer Pilar mounted Boost & Air fuel gauges
White AXS front and rear seat covers
Foot well Neons
Door neons
Roof mounted Black lights (Glows on White seat covers)
Exterior:
Blue with violet pearl 5month old paint.
Full Final Konnexion Body kit (very rare)
19†Shadow chrome HP design Wheels
Turbo timer
Engine:
High flowed Rb20 Turbo
Hybrid Front mount Intercooler
3†Turbo back Exhaust system with Chrome muffler
Bosch 040 Fuel pump
Turbosmart Boost controller
K&N pod filter with Heat shield
Suspension:
Whiteline Springs
Bilstein Shocks
Whiteline Front and rear Heay huty Adjustable Sway bars
Whiteline Front and Rear Camber kits
Whiteline Front and Rear castor kits
Whiteline Diff align
Front Strut brace.
Stereo:
Alpine 12†S type Subs X2
Alpine M1000 Mono block Amp
Alpine 4channel Amp
Alpine Rear 2 way 6.5†speakers
Alpine Front 6.5†Splits
Removing Alpine DVD player, selling with JVC Double din CD player.
Yellow top Battery
Recent Services:
Timing belt - 4000k ago
Water pump - 4000k
Crankshaft sprocket - 4000k
Crank & cam shaft seals - 4000k
Radiator - 4000k
Diff oil - 4000k
Gearbox oil - 4000k
Engine oil - 2000k
Brake and clutch fluid flush - 4000k
Clutch slave cylinder - 500k
Fuel Pump - 1000k
Rear tyres - 4000k
Rear brakes with Disc Machine - 1000k
Air Con. - 1000k
May have missed something.. but feel free to ask.
Very sad to put my baby up for sale, but its time to go.
This car is well looked after, always serviced before.
Asking $18,000. First to see will buy.. Its an awesome car.. im just lookin at a house for now.
PLease get back to me via PM or feel free to call 0402419988
Located in Canberra.
Edited by SkyGTRline
https://www.sau.com.au/forums/topic/154270-r32-gtst-bodykit-pearl-paint/
  • 4 weeks later...
  • 4 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
