Hi guys, on a 500 bhp RB engine we only get between 3 and 6 rwkw from adjusting the inlet camshaft timing, most common is 2 degrees. On the other hand adjusting the exhaust camshaft around 4 degrees gives between 15 and 18 rwkw. I really don't see adjusting the inlet camshaft timing on a VVT road engine is worth it. The car will be slower accelerating anyway because you will loose a lot more than 3 rwkw in the mid range without the VVT.
Hope that adds to the discussion
Hi guys, if I was doing another mid power upgrade on an RB25DET (mid power = max on standard internals) I would go for a set of cams designed for the hydraulic lifters and the VVT. The 2 that we have done worked out just so nice, it has to be worth the extra bucks.
For GTS-t VSPEC, yep we could use one of the outputs from the Motec to continuously adjust the VVT on the inlet camshaft. You could build a 3D map for it, based on RPM, throttle setting and boost level, it would be a bit of work, but you could do it. We would also statically adjust the exhaust camshaft timing with an adjustable pulley.
The M3 is much easier, as it has Vanos on both camshafts, so we can put them anywhere we like, independantly. The XR6 Turbo also has VVT on both camshafts, but the plurb says they move together, not independantly.
On the 2 GTT's that we have done, we used Power FC's and left the VVT staging untouched, in fact I don't remember it being accessable with the Commander. Can't wait for the datalogit guys to do one for the GTST's, open up some nice possibilities.
Hope that helps
  • 10 months later...
[. Can't wait for the datalogit guys to do one for the GTST's, open up some nice possibilities.
Hope that helps
Sidneykid.....I have the FC-Datalogit in my hot little hands right now. Software program is FC-EditRB25DET Ver 1.100. However it is a Beta version....didn't know that when I bought it
Hi Jay, I ordered a Datalogit for the R32 GTST earlier this week. I wonder if it's a beta version as well.
Hi lukits01, you asked "was wondering if anyone has any opinion on running a 256 Ex Cam shaft with the standard RB25DET VVT inlet shaft?""Will this combination work?
Yes works great, not as good as a pair but still worth doing.
"what kind of tuning is involved?"
Lots, do you have a programable ECU? If not, then buy that first.
Hope that helps
Thanks for info sydney kid
I only have a SAFCII
This idea was sorta result of impulse buying hehehe
My ex cam shaft shat itself somehow and I thought might as well get a mild upgrade
since I allready have HKS cam gear might as well finish it off
What about RB25DE inlet HKS 256 Exhaust
that would be a better combination wouldnt it?
No
What sort of power increase is to be expected from the exhaust cam change only?
Also is there any cams that are better suited to a ported head?? I have more power up top now with porting but at the expense of more lag.
cheers matt
Hi Boosted, I have never experienced increased lag with a ported cylinder head, did you do anything else at the same time?
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
