G'day
Mountain bike (Brand new) was a Unwanted and unused Christmas Pressie and the i just had a reverse cycle air conditioner put in so i dont need the heater... the heater just runs off the power point.
Sydney only....
Bike $300
Heater $50
Cheers
~Martin
https://www.sau.com.au/forums/topic/154419-for-sale/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
