Sounds like fund-raising bullshit to me. They don't have differing sensors. Check out a circuit diagram.
I ran my old R34 n/a on the GTT ECU...the only issues were TCS sensors and the like, R33's don't have all the extra bullshit and can just be swapped over.
yeh i've turboed my na, and having a few teathing issues, my air flow metre shat its self as they are different between the models, and the ecu is really struggling just keeps leaning out the car even with a safc, my cheapest option is if i can just swap to a turbo ecu n use the safc to tune there but if i have to change the wiring which 3 reputable places that say they have done it before say u have to its not going to be cheaper than say going to dr drift and getting the ecu moddifyed or getting a second hand microtech and hard wiring it then tunning it
hey been searching everywhere for a pinnout diagrame for an na r33 ecu anyone know where i can find one only found the turbo one and it doesnt help when i want to do a comparison
Do you mind if I ask why your swaping a NA to Turbo ECU?
My last car was N/A + turbo...put the turbo ECU in to make things easier...isn't so with the R34's too much missing bullshit throws up the "check engine light"
R33's use all the same sensors, they have the luxury of no Turbo pressure sensor, TCS, Secondary throttle motors etc etc
The AFM's are the same between turbo and N/A just different between series 1 and series 2's
the reckers i got my air flow meter from said they are different, the sensor is slightly diff or something and the barcode/part numbers are different, nothing that i could tell the diff between thou
I just fitted a emanage ultimate for a guy who turboed his NA R34 and the pins were the same. Rpm didnt work though, no biggy i just used the cas signal. This might be what bought on 666DAN engine light??
so i cant imagine why NA 33 would be differrent.
Edited by URAS
RPM should work, my one did on the e-manage blue, I can't see them changing it for the ultimate??
No, there is a lot to the R34 ECU's which cause the engine light, I know them backwards unfortunately/fortunately :laugh:
i have fitted probaly 20 or so to R33 and about 6 to R34 gtt with Zero issues. The R34 NA one did not like the rpm signal though (it read 5340 at idle :laugh: ) so i swapped it to cas sens and it was sweet. I probaly should have investigated the rpm wierdness but it was not needed.
Interesting, it must be something the ultimate doesn't like. I wonder what the difference to the blue is???
I know for the 350Z you require the rpm signal adapter, maybe it was a late model using a different CAS?
yeah late R33 seies two and R34 require the internal ignition signal adapter and jumpe 8 set to 12v instead of 5v.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
