no no
ive torqued it down in the 5 stages already with a torque wrench
but your supposed to re-torque it after a while cos aluminium expands + contracts so much. i want to know how to do this... cos a gasket is sealed by crushing it you can exactly go through the 5 stages again.... so im assuming you just make sure its on the final torque setting. but am not sure
Adam
Some head gaskets don't need to be retorqued. They are marked as such on the packet.
To re torque it pop the rocker covers and retension to the correct settings in the correct order. DO NOT BREAK THE SEAL by cracking the tension off. I have had troubles doing this in the past.
Some mechanics say don't retorque and I have never got the same answer from two mechs. Your choice but my method doesn't hurt but does take up time......
but the 5 stages are...
22
72
slacken off
22
75
so do i just torque the bolts to 75. or do i knock it back first, then retighten to 22 and then 75?
its just im getting some air leaking into the coolant so rather than having to do the head gasket AGAIN im hoping they just need to be re-torqued
I've allways backed off the bolt just enough so it moves (sometimes cracking noise) then retension at the full torque.
The backing off just gets by the bolt "binding" giving a false reading.
You can try just tensioning and if the bolt moves before the torque wrench goes off that's OK. If it doesn't and you then try the above mentioned method you'll notice the bolt will turn past where it was originally.
Air leaking into the coolant? That's not a good sign.
It's either compression through the gasket or hopefully a loose connection between the rad and overflow bottle which sucks back air when the motor is cooling down. Could be a duff radiator cap too.
Cheers
or bcos ive had the head off and the entire cooling system apart and it wouldnt bleed out in 15mins...
ive replaced the overflow return hose and the radiator cap last week. im hoping its still air in the system. if its a gasket leak im hoping a re-tension will sort it out...
fingers crossd
Originally posted by adam 32
well its gettin worse
still bubbling through the coolant, and ive got no ****in idea whats goin on. invited over a mate whos a mechanic @ toyota and he has no idea
Adam , what do you mean by bubbling through the coolant.
Is it when the cap is off and running, or is it bubbling into the overflow bottle after you have stopped ?
The retension is in case the gasket has crushed some more and everything has settled. Backing the bolt off slightly and retorquing in one smooth movement is not going to hurt the gasket. If it does , it was rooted anyway.
Cheers
Ken
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
