hi guys just wondering iam wanting to rebuild my rb25 just wondering if this will work and what will need to be done to the block.
i want to use rb26 crank to stroke it
then do i need to use 26 pistons and rods or can i use 25 ones
thanks for any help
iam wanting to run a to4z turbo
i was think of using jun internals
https://www.sau.com.au/forums/topic/154689-rb2526/
Whats your budget dude?
If you use the RB26 crank, rods i think the RB25 pistons.
Someone will confirm as a lot have done it.
I just used the RB25 crank/26 rod/25 piston
it is going into a stagea so i want about 300kw
so i can just use a forged 26 crank rods and pistons
what the deck height will the pistons go to high
https://www.sau.com.au/forums/topic/154689-rb2526/#findComment-2877209
26 rods and crank and pistons will do it. Same deck height and rod length remember.
25 pistons on 26 rod and crank would be sitting proud of the block at TDC
so BD Dave i can just 26 crank and rods and pistons and i wont have to do anything to the block or
https://www.sau.com.au/forums/topic/154689-rb2526/#findComment-2877409
26 crank has longer stroke, rods are equal (in size, but 26`s are stronger), pistons are different. block height is the same, head cc is almoust th same (25 a bit smaller)
26 or aftermarket rods is a must as 25 rods are weak.
26 crank + 25 pistons will have CR too high or what BHDave said.
The best option is 26 crank+rods+pistons in 25 block. i do the same thing for myself now.
https://www.sau.com.au/forums/topic/154689-rb2526/#findComment-2877447
You have to check that there's sufficient clearance in the block for the longer throw crank and the big ends of the rods, so maybe a bit of machining there (some one will have to confirm as i haven't dummied one up to check). As you'd probably put in new pistons anyway it's just a matter of machining the bore to suit the new pistons (assuming .5 oversize).
https://www.sau.com.au/forums/topic/154689-rb2526/#findComment-2878458
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
