  • Replies 60
Yeah, I have a feeling the bleed valve is dodgy since it was a home chop job by the previous owner. Its been taken in and out before because the car had to pass the pits.
Spoke to a guy at a workshop that I've booked in next week, he says its probably a dodgy piece of vacuum hose and they can replumb it for me, or just take the whole thing out and put it back to factory boost (which isn't a bad idea considering stock internals) so that way I'll at least be able drive past 5000rpm safely. Pretty simple job, but I guess I'll leave it to a pro to fix as I've been quoted about $60 for an hour's work on it plus the cost of a new bit of vacuum hose (although I reckon your average mechanic will probably fix it in 10 minutes).
Will let y'all know how it goes when the car goes into the shop. Thanks for all the help people :)
All done. Just took out the bleed valve and replaced the vacuum hosing for about $20.
The down side is now the car doesnt feel half as fast as it did before I took the valve out and the boost was going through the roof :rolleyes: but I suppose at least my turbo isn't going to blow...
The car is boosting happily away at 0.4 bar now all the way to 7000rpm(?) limiter - which brings me to my next question: my redline is at 8000rpm so why is my limiter kicking in at 7000? it just bounces on 7000 and doesnt want to go any higher. The boost cut is gone however.
is it possible that the redline was lowered with the powerfc previously installed? is this hard to reprogram if so?
If not, does this problem sound like anything else?
Sounds like your boost has been returned to the stock output [by way of the vacuum hose replacing it - as you said]. So boost should be approx .55 bar [which = 7.9 psi]. Of course your boost limiter wont be there anymore...it isnt reaching high enough to hit this limiter [which is supposedly 1 bar]. You can probably ignore the factory boost gauge because it isnt accurate and its not in bar or psi anyway [kg/cm2]. Where did you get your figure from [0.4bar]? An aftermarket gauge or what?
Rev limit from factory is somwehre between 7000 - 7200. I know this because I have a stock ECU in my 34 and have recorded on a dyno up to 7100rpm and YES mine cuts out occasionally when I hit this range too.
If your display / rev gauge is not the original nissan one [such as tommy Kaira / Nismo etc] then the actual REDline marking could be anywhere [such as 8000] but the factory rev limiter may still be in operation [at the default value of around 7000].
I am sure the PowerFC would be able to control the rev limit but this is the risk you take when buying a modified 2nd hand car - risk as in, you dont know what your getting or what settings there are. You are asking some questions that are unique to your car and can't be answered by any of us! I hope I have been of some help though!
If you want more power get someone to put a bleed valve in properly or get an EBC [electronic boost controller]...If you are used to your car's power with more boost than stock, of course it is going to be slower now...
Zahos: nah, the guy took it out. I figure if I want to increase my boost I might do it later with an EBC of some sort, or at least some sort of in-car adjustable valve.
NismoR34: I got the reading from an Apexi a-pillar boost gauge. It sits on 0.4 all the way to 7000rpm. My dash is the stock Nissan dash and I'm quite sure the redline on the tacho starts at 8000rpm - so does this mean that the redline on the dash isn't really the redline set in the ECU? Does your dash have redline markings from 8000rpm?
All this could be purely academic if the engine shouldn't really be revving past 7000 anyway, regardless of where the markings on the dash are - I realise that. But I'm just curious why it cuts out at 7000 when the redline on the dash is at 8000.
And one last thing, 0.7 bar the figure I'm getting to be the safe boost level for stock internals/turbo on an R34 for street use - can you guys confirm this?
And yes Nismo/Zahos you guys have been a big help and its much appreciated :P
No worries....
Yeah, 0.7 should be quite safe. You could probably run a little higher for street use (squirst here and there), but 0.7 should be just fine.
Zahos
No my markings start at 7000 which is a broken red line [- - - -] and then the unbroken red line [----] starts at either 7500 or 8000 approx and goes all the way to the end of the tacho @ 9000rpm!
*brainstorm* With the vaccum hose that now sits in place of your previous boost valve, did they put any restrictors in there? I am guessing they havent! The standard hose has 2 metal restrictors inserted at either end of this hose, when I removed these 2 restrictors the boost dropped! This sounds like what you now have. Which is less boost than standard. I dont know where you could get restrictors from so I would suggest getting a boost controller in ASAP!
Yep. Just spoke to my mechanic, he says boost is pretty low at the moment (0.4 bar or around 6 pound) and that he regularly sets up customer cars up to 1 bar boost on stock turbo/internals safely (although he'll have to dyno it to test and make sure nothings going to blow up). I plan to get some EBC or dual stage boost controller. Mechanic said the cheapest way is to go the bleed valve/boost cut defender option and stick it up to 1 bar or thereabouts.
For the moment, the boost is going to have to wait - my alignment is out, and the wheel alignments were out by varying degrees on the left and right sides of my car - suggesting an accident and the need to use a chassis alignment rig (*sighs at buying cheap accident repaired japanese import*) to stop the car pulling to the left on a flat road :P
Oh as for the redline, my mechanic said that theres not much point going over 7000 anyway because the car drops right off its power/torque band at around 6600, so I really should be changing gears about then anyhoo.
I'll have to go home and double check my dashboard redline.
Your redline will be the same as mine - unless u have got an undercover GTR :(
I just remembered an ultra-cheap way to increase boost a little - use a cable tie to crimp [restrict] the hose a little bit. The other cheap way is to do what I did, fit a bleed valve. I fitted mine myself and it cost me like $25 total. Check for sale section or post a thread in WTB there may be some for sale around this place.
If I were you I would only increase the boost up to around 10psi or 12 psi at the most [1 bar is 14.5 psi]. HPI's r34 GTT project car had their turbo blow up at just .85 bar whilst flogging it around the track. You may not take yours on the track but do you wanna risk it for the sake of a bit more power now?
Most sensible people in the "turbo car" industry agree that 2-3 psi above standard is okay for stock turbo's / engines. Standard being approx 8psi. Its up to you though!
Hey mine pulls a bit to the right, but not too badly.
Dyno testing can be very helpful in finding out your cars power, boost setting, air/fuel ratios, state of tune, problems - like detonation etc...I had mine dyno'd and power was peaking at 7100rpm's when the rev limit kicked in so changing gears earlier on mine is not optimal especially in drag racing...Nissan quote 6400rpm as peak power on a standard car, which most of ours are not...
:confused: now you have made me wanna go and check mine...though I am already 99% sure it starts at 7k...
icon3.gif...another brainstorm, instead of going out to the garage which is all of 10 metres away I will sift through a hundred odd photo's on my pc cause I am sure I have got a pic of my dash here somewhere...*goes and browses*
...hours later [:)]...
icon3.gifah ha, in fact I posted a pic on SAU before...now I just got to find that link...
aahh there it is
See 7000rpm redline! If your dash doesnt look like that then it isnt the stock nissan one [for a 34GTT].
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
