ok b4 i start i du know its a wierd idea but would i b able 2 make a custom plenum and fit the carburetor whyle still running the factory ecu faving disconnected the injector signals and afm and oxy sensor etc so its only function is 2 control the timing and tell me what the engine is doing on the factory dial cluster (i dont like big after market dials)
the reason is to try something diff i want 2 try it on a high comp rb25
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/
its doable with the right tools and carbys.
you'd need to trick the ecu into thinking all the fuel inputs were functioning correctly, eg AFM, TPS, Air Temp sensor etc.
you'd be better off running a microleb or EMS or something
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2884982
I had thought about getting a RB30e decking the head so you get a 10:1 comp ratio. then putting on 6 throttle bodies from a GTR and retain injection
250 for the motor
300 for the throttle bodies
few $$$ for fabricating
you would need to do away with the AFM and work out some way to read air volume like a MAF.
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2894142
Povo pack GQ Patrol used a carbie RB30, see if you can find one and see how the timing is managed
the gqs use a vacum advance in the dizzy, all the fuel injection stuff bolts up to a gq, so i cant see why the carby gear wont bolt up to a skyline. try looking on some of the 4wd forums you should be able to find a carby manifold fairly easilly, ive threw a couple out over the years.
try http://www.outerlimits4x4.com/index.php
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2897036
iv tried looking for patrol parts but cant find any i thought they were single cams which would mean the manifold wouldnt fit a twin cam head also this means that the dizzy has nothing to attache to as the single cams dizzy is recessed into the head and runs of the cam shaft
the reason for the conversion is for the revs but also the sound (iv heard that a carby rb sounds insane) and i also enjoy a challenge
regarding the maf sensor i didnt think it affected the ignition. what does it do?
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2906068
my understanding is if your ingition maps come from rpm vs load (afm value) your going to need the afm to figure out when to fire those spark plugs
unless you change your ingition system to something else or you go programable aftermarket managment then you could get load from something else , tps , map sensor
Edited by arkon
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2908639
so as the air flow increases does the ignition advance or dellay also would it work if i were to confuse the ecu telling it that there is a set ammount (not chanjing) of air entering the engine throught out the rev range (i know hot 2)
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2911716
when load and rpm increase the ecu advances ignition
you could leave it static but it would run like a dog
you could go to a mechanical ignition system (dizzy) if you wanted . these have mechanical systems to advance ignition timing as load and rpm increases usually some sort of manifold pressure advance or wieght system adjusted by rpm
the whole thing is not realy worth it though theres a reason we abandonded carbs and distributors , they are old tech , unadaptable and inefficient .
an rb26 revs to 8500 with ease , how much more revvy do you need ? try and adapt the rb26 head to your n/a perhaps ?
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2911988
its funny coming from an AE86 background to listen to this talk of revs!
doesnt matter how big your cams are, how high your compression is or how many throttles or carby's you stick on it: RB30's wont rev high because of their bore/stroke ratio.
you wanna build a tough, hot sounding NA screamer inline six? Slap an RB20 crank in an RB25
Destroke it to 2.4 and use a twin cam head capable of the revs you want.
(or just use a turbo engine you pansies)
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2912349
