Iv been searching pully kits and from what ppl say it gives you more throttle response due to weighing half the weight of stock pullys and also looks better. Does any one use them, what are the cost of a good set and are they a defect?
Cheers
Dave
https://www.sau.com.au/forums/topic/154988-pully-set/
even if it looked better you wouldnt see it due to cam gear covers
That would be cam gears under the cam gear cover.
Pulleys are indeed visible, although the fan and shroud obscures much of them, unless you run a thermo of course.
But as Ryan basically said, don't bother, if you're serious get a lightened flywheel.
Light rims will make a difference too.
https://www.sau.com.au/forums/topic/154988-pully-set/#findComment-2883263
lightened flywheels arnt all that they are hyped up to be either...
U know your getting old when u mod your car and once u hit a certain pont it feels more like it belongs on a race track than a daily driver...
On/off clutches, cars that dont idle, or sit in stop start traffic aint fun to use as a regular transport some days...
*goes back to sit down in recliner with slippers...
https://www.sau.com.au/forums/topic/154988-pully-set/#findComment-2883949
GFB don't make a pulley for the RB series because they believe it'll be detrimental to the life of the main bearings.
Pulleys are a waste of time anyway. The biggest 'inertia' mod is the flywheel. You are saving up to 10kg on a mass which is *much* wider in diameter. Thus the inertial penalty is huge compared to a shitty pulley. Don't waste your time on them.
https://www.sau.com.au/forums/topic/154988-pully-set/#findComment-2895631
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
