i'd hardly think it'd be possible to get a good final result based purely on using the weight, wheel-base and track specs of the vehicle and feeding the info into a computer simulator. You can only go so far with computer theorizing before you'd actually need to do some real world testing with the car in production spec.
The new A380 Airbus was designed and tested completly by computer programs, no wind tunnels, no prototypes. It is amazing what they can do. Just an interesting point since you mention the real world testing issue above.
I think it's been around for like 20 years or so.
I'm pretty sure GM invented it (or the other stuff that hsv is using) years and years ago in america.
I thought everyone on here would be aware of it existance.
great, every time you drive down the road you'd be like a streetsweeper, picking up old rusty nails and bits of wire.
Start of the trip your car weighs 1400kg and by the end it weighs like 14000kgs....................lol
HSV GTS Magnetic Ride Control
From an owner
The shocks have the fluid filled with metalic particles and a current runs through the fluid, the current can be altered making the shocks firmer when needed. The track setting is always firmer. There are sensors in each shock that can adjust the settings, they read the cars steering, braking, cornering forces every 100th of a second and adjust the suspension accordingly.
e.g. you hit the brakes, the front shocks get a current through them to firm them up, this stops the nose diving under brakes and reduces braking distances. Likewise you corner hard, the outside wheels are firmed up to stop body roll, you accelerate hard and the rear shocks are firmed up to stop the back dropping and the nose pionting up.
IMO the HSV setup is supperior to that of the Bose system. The main advantage of the MRC's found in HSV are costs (far cheaper) and packaging (far smaller). Top of the line ferrari's and Audi's TT along with Caddy's top of the line cars now use MRC.
I want it!
http://www.spikedhumor.com/articles/81312/...ion_System.html
(Note its in French but its pretty easy to get the point).
And I just went and got the Bilsteins and whiteline kit installed :(
This always happens to me :)
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
