Just looking into buying an Eboost2 controller and some new gauges.
I've hit a wall deciding whether to get a boost gauge or not as Im not sure whether or not the Turbosmart Eboost2 controller has an actual boost gauge within its display. As I obviously dont want to have a separate auto meter boost gauge next to my eboost displaying the same info when i could have a voltmeter or another gauge etc. And I need to buy them at the same time as I am making a custom panel to mount them in my dash for a factory look.
So my question is, to anyone that knows or has an Eboost controller, does it have a boost gauge which stays on while your driving, working like a digital boost gauge? Or does it just tell you what the boost is set at?
I have tried ringing a few autobarn stores which sell them but nobody seems to know what they are on about, just giving me ummms and aaaahhhs.
https://www.sau.com.au/forums/topic/155067-eboost2/
This might help you a little if you already havn't checked it out, it gives you downloads of instructions which should give you some insight...
http://www.turbosmart.com.au/index.php?id=42
Yeh i had tried that before originally posting, the PDF files are corrupted and wont open.
https://www.sau.com.au/forums/topic/155067-eboost2/#findComment-2885027
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
