Big up the four door! Look, I'm a fan of both. Ceffy; great, S13 chassis with RB20 can you go wrong? 32 four door. Looks, RB, solid as a f**king rock! Love mine!
It's up to you mate... you won't be losing out either way...
But get a 32! :)
Thanks mate. I do own a S13. But currently is a Big Project for me to finish. I knw wat s13 feel like. But i change my mind n sale the s13 n get 4 door. My s13 got a very bad hit before which is from pervious owner. The car now is juz the Shell no panel left on them. So, i decide 2 get 4 door n slowly modify them.
Thanks
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
