i noticed the rubber bits shown in the pic are leaking this jelly type stuff. they are the rubber grommets between the rear subframe and the chassis.
i have a 2way diff, and it shakes the car to bits around corners, and even when the front wheels a slightly turned, would these worn components be the cause?? i know 2ways do clunk but this thing is rediculas, it actually wobbles the whole rear end and is quite embarissing.
any got a price for an upgrade set?
thanks
steve
Edited by PHATR32
  • Replies 48
Posted Images
I've been quoted $200 to fit the Noltec Subframe bushes.
They are a hassle to do but providing the workshop has done them before they can get them done quickly. If they want to. >_<
I've just bought a 12tonne press so I will be doing my own shortly.
$200 that cheap I never got a quote but thought it would heaps more , good luck i heard it a prick of a job
Those metal spacers go in a different spot too
exactly....200 is a steal....don't do it yourself if you can get it done that price....you have to take the whole subframe down to do it - have a look how much you need to detach to get it off
Mine have stopped leaking.
On the dyno under power the left wheel 'almost' touches the front of the guard. :S
Driving it on the road second and sometimes third steers the car. :P
Good thing they are being done soon.
lol. I found after i locked the hicas i'd chuck the car into a corner and the arse end would still passively steer :(
I think the 2 way will be giving the bushes a very hard time. All the loading and unloading (which would effectively be twisting/releasing the subframe), both wheels trying to travel at the same speed on accel and decel will probably twist the subframe on fast cornering aswell, so effective passive rear steering.
so the actually sub frame has to completly removed?? dam....
what are these lock collars sh@un is talking about?
i've been quoted that they would need my car for at least 1 full day... is it THAT big of a job?
Yes, they have to remove the whole rear subframe from the car to put it in the press. That means drive shafts, diff, tailshaft, stabilsier bar, shocks, springs, brake callipers, habd brake cable etc etc all have to be removed first.
If someone is quoting $200 then it is either;
1. A new guy who has never done one before and has no idea how long it will take
2. A suck in price, they will find something "wrong" and then charge more
3. Someone who thinks that they can do it in the car with a screw style press, when 99% of time they can't. One or more of the bushes will not budge and they will have to remove the whole subframe. Then refer to #2
:( cheers :)
:( cheers :)
Gary, The bloke is my tuner. He's done a few of them before and knows they are a big job.
BUT thats the price he's given me. No doubt others would not receive that price. :)
He removes the diff and all the associated bits. Gets an oxy on to the old bushes and wacks them out (apparently much quicker doing it this way than removing the old via a press). He then wacks the subframe in to a press and presses in the new bushes.
He did say its a 1/2 to 3/4 day job.
I got quoted the same price as Cubes for changover of the subframe bushes through our tuner.
He does do slightly better prices because of a thing called customer loyalty, not that he doesnt know whats involved, or a suck in price.
In fact when he sets the price its fixed, no matter what. Unless something goes stupidly wrong he will ring and ask u about it.
GTR32GUS - The metal ring ones simply crush the std worn bushes down providing a metal on metal connection between the subframe and the rear of the car. Not the best option for someone with a 2 way diff..
Pinapples can be used to stiffen the subframe up, or change the angle of it .
Edited by Bl4cK32
dam, looks like its gonna be a weekend job then.
about the press, do you really need a big one, are they that tight they cant be hammered in?
back before i registered it i had most of the ass end out it (diff, shafts, attessa pump), etc etc so removing it isnt a problem, the problem is i dont know anyone who has a press, and i wont have much luck finding a shop open on a sat arvo or a sunday.
steve
I bought an Ebay 12tonne press for $150. The bloke was in adelaide so no postage cost, usually postage is around $38.
Its quite a good press and much better than the supercrap presses that break welds.
Grab a 3" piece of exh. pipe and plate to press the R32 bush in.
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
    • This sounds like a perfect excuse to install a Haltech R3.
