alot of people are going to hate this.. but 400R fronts are ghey.....
i kno wot u mean! i think the same to much holes and bumps n lumps... plus heaps around!!
Thats why im after some opinions of something different
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2887057
Go trust frount bar i searched for agers and its the nicest bar around. Im only stuck with finding side skirts and a rear bar as i have gtr skirts and gtr pods but want a bigger and smoother skirt and rear bar. What do ppl think of the veilside skirt and rear bar as i think it would be a perfect kit
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2888750
these kits have all been done to death I guess......
I'm basically tired of looking at Trust bodykit.....that massive hole in the middle looks super gay
Uras kits on R33 are so over rated, everyone says it's so great but I got tired of looking at it from day one.
The only combo I like is a GTR front bar with a 400R skirt and Rear Bar topped off with 33 GTR rear wing but square wing's ok too.
if all that fails, I think the series 2 look is the most funky and best designed factory look out of all the GTSTs
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2891828
Series 2 are nice if it wasn't for those big twin light things they got going on. Besides that I like the type-m s1 bar when modified 'correctly', by that I mean cut out middle bit, with the cut out edges plastic welded and repainted with a GT-R style grill added for a bit more aggresion
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2892461
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
