  • Replies 159
Posted Images
ok.. so i was driving to office works to get some books and stuff so i can start pretending im doing work for the new semester.. when this f**king blind bitch drives into my lane. i clearly wasnt going to let her in, im just not that kind of person who tolerates lane cutterinerers.
anyways.. she kept going! like a f**king dumbass she lets herself in almost hitting me. so i was forced to stop and let her in. so i have my usual road rage moment then settle.... i look up only to see those f**king flowers.
my skin colour is pretty dark, i am teh darkness! but anyone could've seen i was going red with rage... i couldnt take it so i asked god for a sign to whether i should do something. and i got one. she turned into officeworks too!
i park my car and waited for her to go inside, i took out my stanley knife and walked over to the car. i only managed to get 2 of those f**king flowers off till someone spotted me. i walked inside and got my stuff, she was gone by the time i got out so i couldnt take any pics.
this is the only one i got of her letting herself in.. after i talked myself out of stabbing her.
And its a friggin TAXI
  • 10 months later...
well, i only took the photo of that sticker today :)
:D
too hard to start a new thread??? :D ... Now im going to start noticing those farking things again....
thanks alot Sh@un :down::D
welcome to yest.....oh fcuk it
bwahahahaha
too hard to start a new thread??? :bunny: ... Now im going to start noticing those farking things again....
thanks alot Sh@un :D:banana:
bwahahahaha
then i'd have to put up with the inevitable '2007 called, they want their thread back' jokers
it's all about continuity
c-o-n-t-i-n-u-i-t-y :bunny:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
