paulr33 Posted February 9, 2007 Share Posted February 9, 2007 ive never understood the good idea behind a catch can why not fix the source of the oil leaking? Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2894388 Share on other sites More sharing options...
Guest 40th-edition Posted February 9, 2007 Share Posted February 9, 2007 i had a problem of getting pipes to bend off that top rocker cover breather... it keeps kinking! Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2894464 Share on other sites More sharing options...
bubba Posted February 9, 2007 Share Posted February 9, 2007 (edited) Catchcans are just a bandaid for tired engines with a bit of blowby.. kinda like my ol' rb20 Edit: 40th.. I just used a larger radius for the bend or you could try ENZED or something to get some elbows Edited February 9, 2007 by bubba Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2894946 Share on other sites More sharing options...
Nathan_G1 Posted February 9, 2007 Share Posted February 9, 2007 personally im not a fan of catch cans at all.......theres just something about them that screams dodge to me, unsafe even Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2894990 Share on other sites More sharing options...
r33_racer Posted February 9, 2007 Share Posted February 9, 2007 In racing you are required by rules and regs to run a catch can that holds a certain litreage. Also they arent there just to catch oil or bad breath from sad motors, perfectly healthy engines still have oil in the head and during corners or even acceleration oil and oil vapour can escape the rocker covers. Every engine has to breathe. A catch can just lets it breathe without feeding contaminated air into turbo/intake. If you want to run it properly/illegally, dont run it into the intake, and put a breather on your can. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2895010 Share on other sites More sharing options...
jimmytim Posted February 10, 2007 Author Share Posted February 10, 2007 Okay, how about this? Better? Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2896228 Share on other sites More sharing options...
SECURITY Posted February 10, 2007 Share Posted February 10, 2007 yep Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-2896911 Share on other sites More sharing options...
H@ME Posted November 3, 2007 Share Posted November 3, 2007 jimmytim said: Okay, how about this? Better? SO this last picture is the correct way for running an oil catch can, wat type of oil catch can was used. how many inlets etc, i have a Greddy oil catch can i want to fit soon, was just wondering on this thread if it was the correct way for doing it for an rb25det, anlso was a breather used here? have u had any problems or noticed a difference anywhere? hamish Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3452989 Share on other sites More sharing options...
Basti Posted November 3, 2007 Share Posted November 3, 2007 jimmytim man thats a lot of pipe. why dontcha trim it to the correct length? what can are you using btw? hamish i dont think that a breather is used in this setup. the air is returned into the intake Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3453202 Share on other sites More sharing options...
linedup33 Posted November 4, 2007 Share Posted November 4, 2007 it looks like a d1 can from justjap. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3454112 Share on other sites More sharing options...
jimmytim Posted November 11, 2007 Author Share Posted November 11, 2007 linedup33 said: it looks like a d1 can from justjap. Yeah, it is the D1 can.... I've checked the can, it is dry as... There really isn't any point in running it Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3466892 Share on other sites More sharing options...
WazR32GTSt Posted November 11, 2007 Share Posted November 11, 2007 the last pic is hte 100% correct way of having it trim down the hose and it will look a lot more neat also, if i were you i would try to mount it somewhere near the coolant reservoir in the fornt corner of the engine bay.. where you have it now is too close to the turbo and heat + oil is no fun! Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467252 Share on other sites More sharing options...
Basti Posted November 11, 2007 Share Posted November 11, 2007 ok i have a question. from what i have read in other threads, there should also be a return line from the can to through the PCV valve (relocated) and into the plenum to prevent it from sucking oily air from the driver's side cam cover on idle. does this air have to come from the can? i mean can i run a setup like jimmytim and just have the pcv valve pulling external(underbonnet) air? Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467379 Share on other sites More sharing options...
rob82 Posted November 11, 2007 Share Posted November 11, 2007 Basti said: ok i have a question. from what i have read in other threads, there should also be a return line from the can to through the PCV valve (relocated) and into the plenum to prevent it from sucking oily air from the driver's side cam cover on idle. does this air have to come from the can? i mean can i run a setup like jimmytim and just have the pcv valve pulling external(underbonnet) air? It would then be a vacuum leak. Not sure in the picture of the engine bay - where does the PCV hook in? If the can is venting to atmosphere and the PCV is still attached then its an incorrect installation. Unless you racing the car or there is a reason for excess engine breathing then just leave the factory PCV and rocker cover venting hoses standard as there is no gain on a slightly modified engine, apart from the slight reduction in octane as the oil mixes with the incomming. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467460 Share on other sites More sharing options...
Basti Posted November 11, 2007 Share Posted November 11, 2007 the Positive Crankcase Valve is a one way valve, pulling air from the cam cover on idle when the intake plenum pressure is low and closing when intake pressure is high (on boost). the actual valve is in the cam cover itself so ppl usually move it to the plenum and run a hose from the catchcan to it. similar to the one going to the intake pipe after afm. so you have one hose (or 2) from cam covers to can, one to the intake pipe and another thru pcv into plenum. if the pcv is just gonna be sucking can air anyway, does it matter if it sucks ambient air? i assume no because the hole is small for one and the valve is only open on idle. anyone care to correct me? Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467526 Share on other sites More sharing options...
daxter Posted November 11, 2007 Share Posted November 11, 2007 When installing my catch can I never blocked off the PCV as its only open on idle so not much oily air will be going in. Only install the catch can on the intake side to stop oily air going through the intercooler. – Same way jimmytim has it. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467628 Share on other sites More sharing options...
rob82 Posted November 11, 2007 Share Posted November 11, 2007 Like I said if the PCV is drawing in ambient air then it is a vacuum leak. If your still running a AFM then this air is not being accounted for and hence will slighlty lean the mixtures out under vauum condtions. And no the PCV is not only open at idle but all rpm under vacuum. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3467716 Share on other sites More sharing options...
33_skyline Posted November 12, 2007 Share Posted November 12, 2007 Just so some of you guys can see, this is how the mechanic set mine up. I do plan on putting to braided lines to the catch can just been lazy. We also found I needed a breather on the rocker as it was pushing oil out the exhaust. I also still have the PVC valve connected but again I haven't got a plug made for it, with it still connected it cause a little hunting on idle and a flutter noise in the exhaust note when just cruising on steady idle (ie 60km/hr) Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3468615 Share on other sites More sharing options...
H@ME Posted November 12, 2007 Share Posted November 12, 2007 hey i going to install my catch can as it been sitting on my shelf of parts in the shed for ages, which is a better place to mount the can? i have provided pics. Looking at the car from the front, i either going, the left strut tower (drivers side) or the right. howeveer the turbo is on the right in standard position. so any advice would be good, also should i block the bottom inlet? Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3468651 Share on other sites More sharing options...
linedup33 Posted November 12, 2007 Share Posted November 12, 2007 i reckon the left side is better as its away from the exhaust side coz if it leaks oil then there mite b a fire. Link to comment https://www.sau.com.au/forums/topic/155526-i-dont-think-this-is-the-correct-way-to-install-a-catch-can/page/2/#findComment-3469273 Share on other sites More sharing options...
