  • Replies 41
Posted Images
Catchcans are just a bandaid for tired engines with a bit of blowby.. kinda like my ol' rb20 :)
Edit: 40th.. I just used a larger radius for the bend or you could try ENZED or something to get some elbows :)
Edited by bubba
In racing you are required by rules and regs to run a catch can that holds a certain litreage. Also they arent there just to catch oil or bad breath from sad motors, perfectly healthy engines still have oil in the head and during corners or even acceleration oil and oil vapour can escape the rocker covers. Every engine has to breathe. A catch can just lets it breathe without feeding contaminated air into turbo/intake. If you want to run it properly/illegally, dont run it into the intake, and put a breather on your can.
  • 8 months later...
Okay, how about this?
Better?
SO this last picture is the correct way for running an oil catch can, wat type of oil catch can was used. how many inlets etc, i have a Greddy oil catch can i want to fit soon, was just wondering on this thread if it was the correct way for doing it for an rb25det, anlso was a breather used here? have u had any problems or noticed a difference anywhere? hamish :rofl:
jimmytim man thats a lot of pipe. why dontcha trim it to the correct length? what can are you using btw?
hamish i dont think that a breather is used in this setup. the air is returned into the intake
the last pic is hte 100% correct way of having it
trim down the hose and it will look a lot more neat
also, if i were you i would try to mount it somewhere near the coolant reservoir in the fornt corner of the engine bay.. where you have it now is too close to the turbo and heat + oil is no fun!
ok i have a question. from what i have read in other threads, there should also be a return line from the can to through the PCV valve (relocated) and into the plenum to prevent it from sucking oily air from the driver's side cam cover on idle. does this air have to come from the can? i mean can i run a setup like jimmytim and just have the pcv valve pulling external(underbonnet) air?
It would then be a vacuum leak.
Not sure in the picture of the engine bay - where does the PCV hook in? If the can is venting to atmosphere and the PCV is still attached then its an incorrect installation. Unless you racing the car or there is a reason for excess engine breathing then just leave the factory PCV and rocker cover venting hoses standard as there is no gain on a slightly modified engine, apart from the slight reduction in octane as the oil mixes with the incomming.
the Positive Crankcase Valve is a one way valve, pulling air from the cam cover on idle when the intake plenum pressure is low and closing when intake pressure is high (on boost). the actual valve is in the cam cover itself so ppl usually move it to the plenum and run a hose from the catchcan to it. similar to the one going to the intake pipe after afm. so you have one hose (or 2) from cam covers to can, one to the intake pipe and another thru pcv into plenum. if the pcv is just gonna be sucking can air anyway, does it matter if it sucks ambient air?
i assume no because the hole is small for one and the valve is only open on idle. anyone care to correct me?
When installing my catch can I never blocked off the PCV as its only open on idle so not much oily air will be going in. Only install the catch can on the intake side to stop oily air going through the intercooler. – Same way jimmytim has it.
Like I said if the PCV is drawing in ambient air then it is a vacuum leak. If your still running a AFM then this air is not being accounted for and hence will slighlty lean the mixtures out under vauum condtions. And no the PCV is not only open at idle but all rpm under vacuum.
Just so some of you guys can see, this is how the mechanic set mine up. I do plan on putting to braided lines to the catch can just been lazy.
We also found I needed a breather on the rocker as it was pushing oil out the exhaust.
I also still have the PVC valve connected but again I haven't got a plug made for it, with it still connected it cause a little hunting on idle
and a flutter noise in the exhaust note when just cruising on steady idle (ie 60km/hr)
hey i going to install my catch can as it been sitting on my shelf of parts in the shed for ages, which is a better place to mount the can? i have provided pics. :angry:
Looking at the car from the front, i either going, the left strut tower (drivers side) or the right. howeveer the turbo is on the right in standard position.
so any advice would be good, also should i block the bottom inlet?
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
