  • Replies 122
Posted Images
Stop ripping me off Grant! Hahaha!
Nice kit!
That kit will bring you lower than the Dayz kit too I think, even if it is just visual and not actual as the side skirts (steps) are a lot squarer.
Cheers
Luke
hey on the skirts, do they sit liek the factory ones or do they slide in between the door like most kits?
Not sure how the factory skirts fit, mine do sit on the sill panel and run under the doors.
(thanks Alex, black car, wash - then photograph before the dust settles)
i still dont like hte height
If i want to go lower, i need to get shorter springs (think 120mm length stupid short) and helper springs.
i have a custom coilover in the works from a guy around here. im trying to get a decent price from him and not some stupid 2,000 dollar price tag.
ok, started fabbing up the exhaust today
i have all the piping from the cat to the sway bar done. i have to pick up some more 3 inch pieces and pie cut and weld them to make the s shape right there.
my aero will be here friday
my gauges should be nere in a week and a half
ORdered a greddy oil filter relocation kit
Ordering NRG Fuel pressure regulator nad AEM UEGO monday
ordering cusco r33 GTR sway bars monday
and hopefully have my wheels sold so i can get some 9s in the rear so i can go uber low.
Where the hell are you gonna relocate your oil filter to, Grant? I can't find anywhere decent to put one without it then being in the way of something else! Most people with Skylines, etc. put them on the front of the driver's side strut tower, but the Stagea has a massive fuse box there, so that kinda rules that out...
pics
fo sho they fit great now!
can you take some closer pics to show what it looks like up close.. and i forgot what else i was going to say :rofl:
nice car anyways :( coming along good. wich i had millions of dollars spare like you
:Shrug: it is the kit specifically for hte stagea. ill have to take a closer look at the instructions to find out where. but its not a universal kit, so it has to go somewhere
what do you want more pics of?
when i get my kit i will sell you the skirts
So whats thie Dayz thing?
i saw the badge but i dunno what it means
thanks i have only just been able to log back on and finally came across this....thats excellent thanks champ..let me know when :wub: send us a pm on what price you would be after and freight to perth :no:
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
