Hi, I want to get 19"*8.5 +20mm offset with 235/35 tyres front and 19"*9.5 +25mm offset with 265/30 tyres rear for my R32 GTST, my guards are already rolled and i have Cusco adjustable coilovers. Does anyone know if they will fit ? :happy:
Edited by SNISMO
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/
It'd go close.
With a +40 on the front you may run into issues with the inside edge scrubbing on the inner guard or possibly the upright. +30 with 17*8.5 works well on the front of mine. The rear would probably fit, but i just can't see those tyres fitting under the stock guard. +40 will put the inside edge of the rear rim pretty close to the the hicas balljoint and the front of the lower control arm. Depending on the camber it will also be very close to the struts/coils of your coil overs.
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/#findComment-2897228
Probably not as the wheel itself is so big.
You can get away with it on 17's, maybe 18's, dunno about 19's, it would depend how low your car is i suppose.
You can always try some wheels out to get a better idea.
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/#findComment-2897744
I just found out that the wheel offsets are +38 front and + 40 rear. Any better or is the rear still going to be a hassle ? Thanks for your helping me out with this too guys, offsets confuse the hell out of me...... :)
Edited by SNISMO
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/#findComment-2900353
man it is fine!!!
I have 19's (8.5 @ front, 9.5 @ back) looks SOOO hot, (but im bias..its mine)
U need some really stiff sus, (which i presume ur coilovers are) I have D2 drift spec, adjusted to the stiffest degree. This ensures you can drop it as low as you can!!! :wub:
I think my offsets are the as urs too.
my fronts needed 225s as the tyres were scrubing against teh strut (i was originally trying 245s with no luck). At the rear i am running 275s look hot as when viewing hte car from the back, and likewise my guards are rolled too.
Good Luck,
Peter :iluvff:
Edited by SEX-DR.
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/#findComment-2905288
man it is fine!!!
I have 19's (8.5 @ back, 9.5 @ back) looks SOOO hot, (but im bias..its mine)
Good Luck,
Peter :iluvff:
https://www.sau.com.au/forums/topic/155711-19-on-32-gtst/#findComment-2905320
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
