Just want to tell everyone that I went to boostworx for a tune (safc) recently and I would highly recommend Shaun's work to anyone!!
I gained 10kw just in tuning/ignition timing because my last tuner was a little too conservative (was still a good tune, but just maybe he doesn't specialise in nissan/apexi tuning as much as others).
Shaun's ability with skylines/stageas is top notch - as many people on this forum will agree.
I'm very happy with my car's extra performance! Worth every penny! (prices are very low too) :D
EDIT: P.S. when I say the other tuner was conservative, for example my AFR's were sitting below 11:1 and ignition timing was either stock or a bit retarded ...Shaun managed to get the AFR's up to a flat line at 12:1 and advanced the timing whilst still keeping it safe. :yes:
Edited by pixel8r
  • Replies 80
Posted Images
Getting my car back 2day and getting my tune there soon after my FMIC.
Good stuff Paul. Try to book early otherwise you may end up waiting for 3weeks to get it in.
My plans have changed.. lol I'm going a GT35r .82 int gate turbine with an xr6 .5 comp cover.
Should do exactly what I want it to. :)
Yes Shuan is a top bloke, Mate and i were there yesterday working on his IP race car, whilst Shaun was working on his! I'm starting to think he needs to employ another off sider! he is always booked to the max, and not too mention they are the "Dyno Day Kings"
Ive decided on Boostworx for my tune on the RB25det stagea. Original 2 tunes were with Graham West Workshops but I feel they are on the expensive side, and was going to go to Turbo Tune but thought bugga it, lets do Boostworx seeing they have such a wide support network here on the forum.
Next Tuesday 27th Feb at 9am for a few hours is the golden day. Dropping the front AWD driveshaft and tuning in RWD mode.
Question to the experts : had the highflow turbo from Slide on now since November, worried about afr's etc with the summer heat (been on low boost, in fact hardly driven it in the heat). Should I go for a 1bar or a 1.1bar tune? Dont want to stress the motor over the next handful of years, as I wouldnt be able to afford a rebuild. Maybe in 5yrs time but not in the near future.......... opinions ?
She's got all the bits bolted on her, such as 040 fuel pump, dual stage EBC, Z32 afm, apexi SAFCii and SITC pigybacks, fmic, cai with pod filter, radiator air guide, etc etc etc, loads of goodies.
A: dont be to soft on it, or she will carbon up to much.
1.5 Bar should clean out the cobwebs and get the stag really humming..
or
b: 16 psi will be fine, just make sure on boost your AFR is around 11.5 and no higher.
and keep pinging below 15 and it will last forever...
if your really concerned about it lasting for years in the heat, then get it tuned on 95 ron fuel,
once tuned only run 98 ron fuel and you will never have an issue when it gets hot.
how much power are you looking for?
Darren
Shaun will see how it goes on the day, i.e slowly wind boost up until the limits of the std ecu and piggy backs are reached.
Do the Stagea's still have the dreaded R&R? This will be its limitation BUT with an adjustable fuel pressure regulator you may be able to push up fuel pressure and then lean it right out with the safc, you won't have to worry about it pinging its head off due to the lesser load points and more ignition it runs as you can pull ignition out with the ITC.
Looks good. ;)
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
