  • Replies 838
Posted Images
currently playing. time crisis 4 PS3. should I be embarresed? :P but hey it was a gift! and actually quite fun. though I really wish the guns had recoil like the arcade ones used to, or at least rumble/dual shock. that would be nice. :D
ive been thinking about gettting tc4, i could finish tc2 on once credit back in the day lol
how accurate is the gun?
yeah it's not too bad. you calibrate it each time you start the game. you can chose 2 point calibration or 5 point. I always do the 5 point. i'm playing on a 46" sony XBR lcd and the sensor cord isn;t long enough to span the width of the TV but it's not a problem.
I tried the FPS part of the game last night. the controls seem so akward at first but it's actually not too bad once you get into it. :dry:
well COD4 runs aswell on the mac as it does on a PC
im on teh minimum X1600 card specs - un-upgradeable as its my laptop
get anywhere from 20 (with heaps of people at spawn) to about 75 fps
ran these commands in console to up the fps - works well:
/com_maxfps 125
/cg_fov 80
/r_drawdecals 1 (0 is off - no papers flying about)
/maxpackets 100
/snaps 30
/r_drawsun 0 (sun off)
/cg_brass 0 (shell ejection off)
/cg_drawfps 1 (shows fps counter in top right corner)
/r_multigpu 1 (on, increases fps even if only one gpu)
just finished GTAIV, talk about the most boring game of all time. at least now i never have to put it back in the xbox.
currently playing...
Far Cry 2 PC - It's ok but not that great stupid little things make it frustrating.
WAR - good fun still i'm only level 11 but it's fun with mates!
currently playing
Fable 2 (x360) Absolutely loving it.
finished sw force unleashed in 2 days prior to purchase of fable.
Will get far cry 2, dead space, fallout 3 and gear 2. Man the 360 is awesome. Meanwhile my ps3 is collecting dust unless i am watching dvd/blu-ray
Haven't played any games on a pc in years. If Star Wars: The old Republic mmo is only pc looks like i may use a pc again.
went and saw max payne the movie last week.. since then i have reinstalled and completed the first game and i am currently playing max payne 2.. they are both still awesome seeings at the first game is roughly 7-8 years old and the second game is 5-6 years old.. much fun :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
