Aus. spec SR20det and auto's are 370cc from my info.
Yea thats really interesting, i have one friend with a aus spec r s15 and his are the purple colour ones, another friend that has a s15 aus spec r 99 model, it has maroon ones... confuses the shit outa me
but yes all jdm appart from auto came out with maroon (so i've seen so far)
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2905237
side feed with purple tops out of R33 skyline and s15 AUTO are 370cc,
with maroon tops out of S15 MANUAL 448cc and the JDM are 480cc from what I've heard
as i'm going to put these injectors in my R33 (maroon tops) before I do I will get them flow tested and then will confirm there flow at a given fuel pressure. I've read here and there and everywhere and everybody has a different opinion, so I guess we'll find out once and for all.
Tuners out there should know if they're tuning R33's with this upgrade as they're a pretty popular upgrade.
Cheers matt
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2905993
The problem with the s15 injectors, is they're old injectors.
I would get them ultrasonically cleaned, get the pintle caps changed, change all the orings, etc etc.
Sometimes, they'll flow well, othertimes, they won't.
they're not that cheap at the end of the day after you do all this.
The deutchwerks highflowed injectors seem to be much better.
PS: the s15 injectors always seem to flow about 440 cc not 480
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906702
Definitely only 6-spd manual has the bigger injectors.
Check the part number to be sure.
Nissan Part No. 16600-91f00
Side feed
Terracotta Top Colour
Oval Plug
Impedence : 11 ohm
They do usually flow lower than 480cc when tested as the s15 fuel reg runs a slightly higher rail pressure than s13/s14/r33.
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906747
The whole JDM vs Aus-spec thing is a bit of urban myth. I recall seeing it written by a contributor to HPI + Zoom Mag a couple of years back.
Did my own research and found the parts numbers from Nissan the same regardless of which market they originated from.
Manual spec S15 = terracotta top = 440cc (or more dependent on rail pressure)
Auto spec S15 = purple top = 370cc
Can't believe all you read all the time, so do your own checks if in doubt. :huh:
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906754
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
