Not really, just pointless trying to help people that dont want it.
wrxhoon has summed it up perfectly. I need say no more.
Its either you believe or you dont, and if you dont believe... its more likely than not that you will when your pistons eat a cermic breakfast
Oh, btw, making it richer wont save it from pegging a turbo wheel
At least he will get to blow it up himself, I didn't , someone else did it for me .
I think even then he won't believe he will think his pistons melted, maybe to much carbon?? He will try to find something to blaim other than the ceramic shit of the exhaust tubo wheel..
Geez guys, didnt know I touched you so deeply- its the internet, relax.
You have your opinion, I have mine.
Have I missed something here. I asked a while ago "whats the most boost you have run RELIABLY" on your RB26, no probs. Any more then 14 psi is a risk. OK, noted, advice taken!
I did my tests, its still running the same boost before the intercooler as what it did before with the stock cooler. Because the IC that is on it flows more, it resulted in less restriction giving more boost at the maniold.
Sure there may be some additional exhaust pressure from the increase in power.
Why get upset? Im not going to run any more boost then what it does already.
Im not pushing any more boost then what its been on for the past year.
Now all of a sudden, my turbo's are at risk?? And my engine will eat ceramic dust? Maybe I should have measure exhaust back pressure before and after. Just to keep you guys happy..
I am not giving you guys a hard time on your theory, I respect that and even asked to look at the pistons, then I get my head bitten off? Who gives a shit, what do you have to loose.
The Japs have had more of these for longer then us, so has the UK. I dont recall any mention of engines blowing up when a turbo goes until recently, and its only in australia.
Cubes- I asked the tuner about it. He already tried it when working for advan and you cant run more timing or leaner on a stock internal RB26 and the boost level wont justify it. You just get to the point of increasing timing and it doesnt increase toque/power, keep going a few more degrees and it will knock--- EDIT Actually come to think of it the cooler intake temps would be of benefit
Edited by amosite
the fact of the matter is simple, it can and will fail soon
the mean time between failure is rapidly advancing on 15 year turbochargers.
if you can afford to rebuild it keep going and dont worry
if you cant and dont want to fork out the 5 or 6k to rebuild it and buy new turbochargers then replace the stockers now. either with oem steel wheelies, larger steel wheelies or some other bolt on stock-er-look-a-likes
but for god sakes, dont keep going thinking it wont fail, cos it will
and when it does, youll be upset cos it will be rebuild time
we dont care that you are making xyz on zyx boost or xzy on stock turbo's
but you need to know that its a timebomb and youll regret it when it fails, unless you have unlimited money
thanks for the pics on the fet coils, it was enough for what I wanted. I just wanted to check if they were the same as some coils I saw in japan last month (they weren't ;) )
best of luck with it. btw, what is the record at EC etc?
i can tell you that you should definately make more top end with the cam geard, and more midrange. you can balance one against the other, but a gain of both is possible.
"...Reallyonly trying to prove a pont that 400 rw hp can be made with bolt on's and stock turbo's..."
I have nothing to prove to you guys,
Sure about that
I doubt it will need a rebuild, the tune is safe. Timing is realistic and AFR's are on the rich side. No lean spool, tuned by one of the best in Sydney who tunes all over the world.
Lets get past the my dads bigger than your dad crap and talk..., I have arguably the best tuner in Perth tune my car and his words to me were and i'm paraphrasing here "It will make 450 at the wheels at 1.4 bar but i wont be able to tell you for how long". And that's the point, I bet I can make 500 at the wheels...but for how long. Hooray for people experimenting cause thats how we move forward; but mate its been done and done and done, there is nothing to prove. Except to your mates. You will need a rebuild because nothing last forever and certainly not a a 17 year old RB
I have an 89R that makes 430RWHP on the original build...I blew one of my turbos at 10K kilometers ago at 13 psi/336 RWHP (from memory). My engine is still making good HP and shows no signs of expiring due the ingestion of a ceramic wheel, But there is a body of evidence to say that... (A) Ceramic wheels dont last long at +13psi in a car driven in a "spirited fashion" and (B) Engines expire when that happens.
Just because you dont believe it doesnt make it go away. Get past the ceramnic dust issue on concentrate on the very probably having to fix a broken car issue
As for your original request for help.
Cam gears... to give you more tuning options
Dumps...proven HP on investment.
injectors...maxing them out soon
Fuel pump..its old now
Your a smart guy by the sounds of it I dont know why you've asked for peoples advice but they've given it to you. You've however seem to have chosen to ignore it. Good luck with that, really. ;)
I think it might have something to do with global warming
Edited by Angus Smart
lol
most of these so called "eggsperts", giving advice, don't own a GTR
Happy Valentine's day...hope y'all get a date
Chill
I don't know about you dude but I have owned several GTRS , I still have 2 in my garage and whats more , I can't remember how many times I have built an RB26 .
Having said that I'm definitely NOT an expert, I just post facts, what I have seen with my own eyes.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
