yes, a public carpark (eg shopping centre carpark) is considered a public road.
You can also be fined by the EPA for littering in public carparks.
Pretty much the only place you can do burnouts etc is on a private property or a private road eg out in the bush at your uncle's farm etc, OR at a motorkhana event eg DECA or at Calder Park Raceway drifts/drags etc.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2903937
If i did a burnt out or whatever in a car park where no1 was there... and no1 could see... could they class that as hooning if i posted it on say youtube ?
SERIOUS QUESTION :ninja:.
If a tree fell in a forest and no 1 was there to hear it would it make noise.? (sorry had 2 say it)
As Kaz180 said public car parks an such even service station drive ways are main roads.
If you really have to do this i would use a couple of witches hats and do the burnout between
then to make it look like a controlled situation .But remember you may not see the police when you start but they might see all the smoke and come and have a look..
Its you call..
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904110
They could class it as 'Idiot'...
Shouldn't that be " They could class you as an 'Idiot' " for asking that question....You wanna be a hero and put burnout videos on Youtube feel free do it in the middle of a city intersection just take your number plates off and they will never know it's you but remember to be hanging out the window giving the camera man a big smile and thumbs up so they can see exactly who you are :ninja:
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904221
SERIOUS QUESTION ;).
You want to do a burnout, post it on you tube because you think people will think ur a f'n champion!! U idiot!
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904605
+1 This is the sort of attitude we would expect from a Noble Park twat. ;)
Dear Moderator,
Things like this should invoke a strike against the user, for the simple reason SAU doesn't promote or endurse such behavior. To post such a stupid question should make that 2 strikes in my opinion.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904674
Guest
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
