yes, a public carpark (eg shopping centre carpark) is considered a public road.
You can also be fined by the EPA for littering in public carparks.
Pretty much the only place you can do burnouts etc is on a private property or a private road eg out in the bush at your uncle's farm etc, OR at a motorkhana event eg DECA or at Calder Park Raceway drifts/drags etc.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2903937
If i did a burnt out or whatever in a car park where no1 was there... and no1 could see... could they class that as hooning if i posted it on say youtube ?
SERIOUS QUESTION :ninja:.
If a tree fell in a forest and no 1 was there to hear it would it make noise.? (sorry had 2 say it)
As Kaz180 said public car parks an such even service station drive ways are main roads.
If you really have to do this i would use a couple of witches hats and do the burnout between
then to make it look like a controlled situation .But remember you may not see the police when you start but they might see all the smoke and come and have a look..
Its you call..
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904110
They could class it as 'Idiot'...
Shouldn't that be " They could class you as an 'Idiot' " for asking that question....You wanna be a hero and put burnout videos on Youtube feel free do it in the middle of a city intersection just take your number plates off and they will never know it's you but remember to be hanging out the window giving the camera man a big smile and thumbs up so they can see exactly who you are :ninja:
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904221
SERIOUS QUESTION ;).
You want to do a burnout, post it on you tube because you think people will think ur a f'n champion!! U idiot!
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904605
+1 This is the sort of attitude we would expect from a Noble Park twat. ;)
Dear Moderator,
Things like this should invoke a strike against the user, for the simple reason SAU doesn't promote or endurse such behavior. To post such a stupid question should make that 2 strikes in my opinion.
https://www.sau.com.au/forums/topic/156277-hooning/#findComment-2904674
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
