I would have thought that driving safely and responsibly is what mainly counts on the streets. ;)
Integra Type R should be put against the Type R r34 for matching..
And id rather a nissan then a honda... hey you want fast pickup speed... by a 750+ cc motorbike
Honda do make decent engines , i'll always choose a nissan over a honda... ok from my experience
stock r33 turbo (keyword turbo here!) will beat a type R no problems,
stock r33 turbo (again turbo , keyword) will beat a S2000. the S2000 will keep up for a while but wont hold its power long enough to outrun the 33
Again this is just from my experience people...
I'll go out on a limb and say that a DC2R is more of a sports car, and a more exciting car to drive than a non-turbo R34, espically if the R34 is auto. then it's no contest.
r34 gt skyline = 1370kg, 147kw
1999 integra type r = 1170kg, 141kw
so 200kg less, and only 7kw less. that is why they are faster.
i'd put the missus SSS pulsar up against a natro skyline. it is only stock motor but has 112hp at the front wheels and pulls like a train. it just has a 2" exhaust and extractors (which made a huge difference). it nearly keeps up with midly modded silvias.
Based on experience as well.
a Honda Integra DC2R can outrun a r33 gts25t(stock) of course because it also depends on the age/condition of the r33 and DRIVER.
People with Dc2r's can manage a high 14's qtr mile stock, r33's result vary depending on driver's skill stock (mid-high 14's) some even worst.
my 2c.
I would have thought that driving safely and responsibly is what mainly counts on the streets. :wub:
Yea umm.... i'm sure you've given somone a run on the streets wether it was safe or not... and if you havn't your lieing i can see through your monitor that you are :thumbsup:
But yea safety first... dun worrie i wear a rubber :(
Edit: all seriousness everyone keep racing off the streets :iluvff:
I knew it wouldn't take long for this one to turn to poo.
Just a reminder to everyone, street racing is ILLEGAL and DANGEROUS, and if you want to discuss illegal activities, it's highly recommended that you find another forum to do it on, because we don't take kindly to that sort of thing here.
...anyway, this thread has served its purpose, the question was answered on the first page.
Locked.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
