yep, its Austnet, channel is #skylinesaustralia
im on there all the time.
Yes I have seen you in there ;)
for those who dont know...
you can get mIRC >> HERE << (just right click and save as).
click on austnet in the server box, then type:
/join #skylinesaustralia
But that chat room eats up all your download time so I am not aloud to go in there anymore :sleep:
https://www.sau.com.au/forums/topic/156382-chat-room/#findComment-2907060
