Sorry if you took it to personally but have you done a 2jz conversion on a skyline?
Have you built motors?
How much experience do you have with rb's or even 2j's for that matter?
What do you do for a living, is it automotive based??
10-15k on a rb hybrid to make the same power is that besed on the fact you own a part store, or have sone these engines before?
This forum is over run by people who make statement sbased on there own opinions and no real experience (what they have read or the mates have told them) and by people who are not remotely qualified to make stupid generalisations , which is basically what this entire thread is....
Sorry to say it but it grinds my gears that theres is endless arguement about unqualified statements such as "2j head is shit" or "rb30's arent a race motor" etc... Its almost to the point where you most people with true knowledge (not saying myself by any stretch) are turned away cause they are sick to death of the dribble.
Just read my thread looks like I am having a massive go at you, sorry mate, not my intention. Seroiusly though all i ask for is when people make statements they qualify there statement with experience and genuine facts that is all, sure it is a discussion forum and people have a right to opinion and heresay, all people need to do though is make it clear when this is the case!!!
Edited by Fitzpatrick Speed Works
$4,500 for a 2J
Then the gearbox. Priced the good 6 speed boxes for a 2J, they're nearly that price again.
Then get all new mounts and everything made, and then, since it's not the original motor in the skyline, around another $1000-$1500 or so for an engineers cert.
I'd be assuming the 6 speed box for the 2J has now come down from 6G (Where it was around 3 years ago) to a price of around $4000
So that's $8 500 JUST for an engine and gearbox, no mounts, nothing, not even in the car, you haven't even put a new turbo or anything on it.
So, looking at $9 500 basically (Excluding labour and engine mounts) to put a 2J in your R33.
You said $10 000 to $15 000 for an RB26/30 combo? I'll go a 26/30 combo then. As for $10 000 - $15 000 that's all new turbo, manifolds, injectors, etc, whereas, your 2J is still on stock turbos.
He's got a choice - spend well over $10,000 on a RB26\30 or spend less than that for a motor that can do the same, standard setup.
You can get a well built bottom end be it rb25/26 or 30 for around 3k. Drop in a set of forged pistons and rods, thats bumps the price up to 5k. Cams and springs, 6.5k. Add an ati balancer - 7.5k.
Unsure with the 26's but the 30's have issues with more than 7500rpm when making 700hp, the stock girdle needs beefing up.
I know of a 2jz that just let go with ~450rwkw. Smashed ring lands. :)
It is thrashed daily, especially on the weekends.
I bet that wasn't the engines fault...
Well, I had no idea that the person wanted to purchase the engine to put into a skyline.
But unless the car is already a GTR, there is still a lot to do fitting wise.
Edited by The Mafia
It was fine for months and months prior..
Just one of those 'street' things. Could have been poor fuel + the weather is a touch warm etc etc..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
