I remember a while ago there was a thread going that had details on injectors and what lag times to set it to and where to set them in the power FC software for the Nismo 740cc injectors but I cannot find the thread.
Can anyone help with the info or dig up the thread ?
I need to check to make sure mine are right
https://www.sau.com.au/forums/topic/156604-injector-settings-in-power-fc/
is setting the lag time etc is just to bring the map into range of the power fc running on stock maps is this correct?
so if i completly changed the whole map and tuned it to the correct a/f then do i have to even worry about this ?
Edited by Guilt-Toy
lag time is what it is. lag time. aka response time. this is to compensate for the fact that different injectors take different amounts of time to open and as fuel injection is a pretty precise thing it needs to be spot on.
the compensation however doesn't have to be changed if you are going to do a full re-tune anyway. it's just an easy way out and all it does is run correction throughout the whole map.
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
