doesnt work that way for me Sam :(
From memory (cos i did this packaged with a winery tour for SAUWA about 3 years ago) the more people you get together for it - the cheaper it becomes. The group booking information can be found on the swan valley oasis site - i tried to look it up but my work computer for some reason thinks its an "explicit site" must be all that talk about large balls.
  • Replies 138
also best way to do it - is get people to deposit the money in your back BEFORE the event with the no refunds if you dont turn up policy.
As nice as all you are a lot of SAUWA people say they'll be at an event then dont turn up - so this way you have a commitment out of people and also have the numbers all organised with yourself and the venue.
Guilty...Good plan ma'am
I need some input as to what people would like to do and when.
If we decide to play on a sunday we can only play a maximum of 9 holes (more than likely the front 9 which is far easier than the back 9). If we play on a saturday we can play the 18.
Cost is $12 per person per 9 holes with a discount offered (15%) to group bookings if paid in full in advance. I guess the easiest way to do that would be confirm your spot by paying me 2 weeks before the date so i can pay the booking, and receive the discount. I have not worked out how much it would be per person with the discount that we could receive.
I had thought to make sure as many people as possible can attend would be to plan early. I was thinking March 24 or 25th but that is obviously open to suggestion if thats not a good weekend (e.g. drifting event, or somehting that people would rather attend).
Have I missed any details that you guys want or need to know?
Regards
Brad
sounds good.
i'm up for either 9 or 18 holes, any day suits me except for march 4th (which is probably too close to plan anyway).
so that's my 9or18 holes and availability survey for you.
(i dont know where it is, but i'll look that up myself :P)
Location may also help people make the decision to come or not.
It is in the swan valley on West Swan Road. About 5 minutes from Roe highway. (Between roe highway and Gnangara Road)
Events wise - there is a MaxAuto Action on Sunday March 25th so if you are planning supa golf for the weekend of the 24th/25th... Donna and I would be in for the Saturday for 9 or 18 holes. If you can confirm this date I will drop you the dosh... if you can catch me Mr. Speed-cut! :P
Dude thats just not nice!!! Nissan gave me speed cut to give you guys a chance!!!
Saturday 24th it is. Tee off at 1ish? Decision decided!
Kids are welcome. Keep in mind, kids will slow play while looking for your ball that you lost! lol
Yup,
Saturday 24th at 2pm it is.
My suggestion is to do the front 9 holes as they are easier to play. It normally takes an hour and a halfish to play 9 holes so with a large group i dont think time will permit for 18.
Ill count up the numbers on monday 26th of Feb and make a booking, then take payments. Probably best into my bank account with a PM so i know its done, or other arrangments can be made. Will work these details out next week. Obviousy payments are non refundable.
Does that sound ok to all???
Regards
Brad
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
