Hey guys. Just purchased some 350z 18's and would like to know what the
widest tyre i could go on the rear due to the offset they have. I was hoping
to get a 265/35/18 for the rear's but not sure if i would run into any trouble.
Any help would be appreaciated. Thank's :happy:
https://www.sau.com.au/forums/topic/156810-who-has-350z-18s-on-there-r33/
hey mick, no luck with the guy at work in reguards to tyres.
Good to see your finally got some wheels for the beast :/
Post up some pics when they're on.
or better yet, come round and take me for another spin :(
are your guards lipped/rolled?
simon
Any help would be appreaciated. Thank's :P
hey dude i have 350z 18s on my r33
i run 235/40R18 on the front
and 255/35R18 on the back
they are 8 inch wide
i tried to put 275s on the back but where to big scrubed out
all the time
might be lucky with 265s but 255s fit sweet
hope this heaps
This help's alot. Thank's heaps BEN O.. :domokun:
BEN O do you have traction problems with 260kw?
Also what type of tyre's do you have. Thank's
bridgestone potenza so3 on the front, very expecive
Falken ziex on the rear bout $250 each.
less than 50% tread no traction reving out in second gear
otherwise 255s give excelent grip.
Hey Duncan. Do you think i will fit 265's under the 33? Also what sort of price are the Falkens you have.
Ive rung a couple of places and the options so far are: Maxxis Mav's $318, Sumitomo $310 and the
Hankook K104's for $300 each. All these were in a 265/35/18. :laugh:
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
